Anything else needed for cam/head swap
Which 243 heads are you trying to go with? Are you planning on CNC, Milled, etc
I would have Martin @ Tick Performance spec you a cam. He's very knowledgable.
What intake setup do you have now?
LS7 lifters are a nice upgrade. JP double roller with the torrington bearing, SLP oil pump like you mentioned. Measure for push rod length. Maybe some injectors.
Front timing cover seal. Front cover gasket. Speacial Kent Moore tool to take of the lower crank sprocket and the tool to install one. A 3 arm puller for the balancer. Torque wrench. Exhaust gasket. Head bolts. Water pump gaskets. And quite a few more odd and end things...
Follow the LS1HowTo.com writeup. It comes in handy.
A few of the reccomendations that your asking for will require more information from you. I.E. Budget, Power goals, and so forth....
Good Luck with your build. There is plenty of knowledge to be had from these guys.
If the heads are milled, that brings up your compression, but reduces ptv clearance. Ideally you want to mill according to your ptv clearance and chose a headgasket to dial in your quench and compression.
The 243 heads are a great budget option for you, but id mill them down some and get a cam that you know will work with your ptv.
If you don't have the money to mill your heads.. I would either, One: Use a .040" gasket to tighten the quench and bump up your compression ratio. Or Two: Look into getting a set of 5.3L heads. It's all dependent on your budget and future upgrades.
400 is a very realistic goal for whichever option you choose. They're cam only cars pushing that much to the wheels. So heads and cam should get you there no problem.
