Best heads for a max effort stock bottom end nitrous car!
Its definitely not the norm but I have spun mine that high several times. That said the fast intakes and stock intakes do not make power up there as their runner length is too long. Even with a huge cam the power is not efficient and will peak and then fall off extremely quick. My car on nitrous with a 239/247 110lsa cam peaks at 6250 and Carries to 6600 on nitrous before it falls off. Now Jacobs set up will be different with a different cam but its a good representation of what those intakes need and can do efficiently.
Here is my dyno graph demonstrating how hard a Fast intake will fall off after 6800-7000rpm even with a "donkey dick" cam. Higher numbers were a single .082N jet and a 34F jet, lower numbers were one .052N jet and one .063N jet with 22F jets on each stage AFR was in between 12.2-12.6 on both runs were 20% load on the dyno.
![](https://ls1tech.com/forums/attachments/generation-iii-internal-engine/386453-best-heads-max-effort-stock-bottom-end-nitrous-car-martinsgraph-1_zps55d9fef4.jpg?dateline=1357307616)
Now that said, if my cam had a 112LSA and 248-250 degrees exhaust duration, I believe it would carry power on nitrous like it does on motor, here is a motor pull:
![](https://ls1tech.com/forums/attachments/generation-iii-internal-engine/386454-best-heads-max-effort-stock-bottom-end-nitrous-car-martinsdyno.jpg?dateline=1357307821)
Here is a V.1 Polluter cam with Tooley ported TFS 220's and a Fast 102 LSXRT(truck intake), notice where it peaks and then how hard it falls off:
![](http://i1105.photobucket.com/albums/h344/fbodyjunkie06/Polluter496rwhp.jpg)
You can force a stock style intake to peak at a higher RPM, but it's going to fall off even harder after it peaks if you make it do that.
We can talk about where it makes the most power all day on a dyno graph and what the intake will do and not do. what matters most is what will it do at the track.
I'm going to give you a perfect example. Third gen TPI cars, we all know they had the most restrictive intake in the world. Put on a carb and a performer rpm and pick up 30 hp automatically. Throw a HSR on it and pick up the same.
In stock form the motor was done at 46-4800 rpms. You could see it on dyno graphs just like Martin showed on his LS1. Put a cam and heads on it and it would raise peak rpm and make power but intake was still killing it.
All that didn't matter, in stock form you shifted at 55-5800 and thats where it ran its best time. Even throwing on the heads and cam, you shift at 6300 with the stock intake, not 6800-7000. That's where it ran its best time. The dyno graph would say otherwise. Throw on a HSR and its going to 66-6800
It all goes back to the dyno is a tuning tool. The track is where you see where the best number is going to be attained.
Spin it to win it
Spin it to win it
Spin it to win it
Spin it to win it
Pat G said a long time ago that anything past a 47 IVC event is inefficient with a stock style intake. I have data myself that confirms this, but I feel that a 48-49 IVC is as far as you want to push it before it becomes detrimental to the set-up and where you could of made more average power at a slightly lower RPM which will get the car faster down the track.
Just having a discussion here, no argument on my side.
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
Now you put a single plane intake on it, that's another story.
Just like I said a dyno is a tool. The car I am talking about only ran a TR224 with an ls6 intake and lowering the shift points slowed it down. Conventional wisdom would say that cam and intake wouldn't want it to be shifted that high but its what works for best ET and MPH. No dyno or graph is going to tell you that only the track will. It goes against all what we know but you won't know until you have tried it on the track.
Letting it shift at 6800 slowed it down to 10.40 passes. Putting it up to 7400 allowed it to run its fastest pass of 10.22 and there is still more in it. This is a full weight 3830 with driver f-body, stock 3.23 gears. This is the car on a 150 on the first pass and a 100 on the second shifting at 6800.
I understand that. However, this is a 3500 lb car and a stock bottom end(not even rod bolts). I seriously doubt a stock motor will last very long on a 300+ shot and 7500 Rpms. I think the right combo with the fast 102 setup could get me to my goals. Of course throwing a Vic junior and 4500 would be much easier and cheaper.
#32
dont worry about fly cutting the pistons because if you make that much power to really kill the pistons you will more then likely knock the rods out that bitch before you get to that point unless your tune is way way off..250 or 300 i would def open up the rings..
As for heads i would be looking at some,after market castings forsure..i would not even think about a stock casting..i would want the thicker deck..i would get something like a all pro,trick flow an then send it to ricky @nrc,tony@bes,curtis@rfd or tooley to do a full blown one off custom port along with rolling and milling the heads an chamber softing..i would be going for around 12-1 comp and a big custom ground n2o cam and let it eat..
ill also say at your weight u better do something..because thats a tuff order to do..you got people like me who are for the simple fact 800#s lighter sitting in street trim with ls1 sbe combos..im an 1/8th mile guy though and dont care bout that record..my sbe deal is just some janky *** ****.
#33
your going about it all wrong..your talking about getting a set of badass heads done and tossing all that money into them an then choking the **** out them with a intake..if you got heads that flow say for example 320cfm@.500,338cfm @.600 and toss a intake on it where the ports only peak out at 250cfm..its not a good combo..you going to want a intake custom ported to match them heads so you truely get the best out of the combo.
So you're telling me that flycutting the pistons,milling the heads to 57cc, spraying 300+, and turning 7500+ Rpms is the way you'd go? I guess the motors are much tougher than I thought. Btw I spray 250 right now off the rail. I would do 300 but its blowing through the converter on 250.
Weight reduction will probably be last on the list. At the lightest the car will be 3300-3350 with driver. Btw I still run a 4l60e and intend to keep doing so.
#34
the record didnt get set with a full weight factory headed car
if you want to go really fast you have to make some changes
i think martin could definitely spec you a great cam and any of the heads youve mentioned will make power, but for the times youre looking to run youre going to need a hell of a setup.
i think tfs offers a different exhaust port for nitrous. id get a set and have them hand massaged by someone like tooley.
#35
I really appreciate all the insight I'm getting and it definitely has me thinking hard about the different combos.
#36
Just as the title says. I've been in contact with Martin from Tick and he will be helping me with camshaft selection. I know Martin is a fan of the AI HCR 241 heads because of the additional piston to valve clearance these heads provide. I will be shooting no less than a 250 shot but more than likely 300-400 so the camshaft will be a max effort nitrous grind. I do not care about dyno numbers as I am more concerned with chipping away at the SBE nitrous record. All you nitrous gurus what are your opinions?
AI HCR 241
TEA or AI 243 heads with additional exhaust porting for nitrous
Trickflow 215s with additional hand work by Brian Tooley
Hand Ported 243's by Brian Tooley
Flycutting is not out of the question however I'm concerned with the integrity of the stock pistons with as much nitrous as I'll be spraying. Also I'm not interesting in spinning the car past 6600-6800rpm.
Regards,
Jacob
AI HCR 241
Regards,
Jacob
#37
You are obviously runni g a setup like this. Post more info about your combo, vids of you car at the track, what it runs , weight, etc. Your car sounds impressive and we are always looking for data, info , from somebody that has already done what we are trying to do. Your car is an f body right? The more specific and detailed info the better.
#38
AFR 215 or TFS 215s are by far some of the BEST stuff I have seen out there and used. TFS stuff needs touched a bit if your running .600+ lift. What kind of N20 system are you running? Direct port I imagine? There is some concern here imo, depending on what intake manifold you are running.
#39
#40
as for wanting to do it with that much weight an that trans you have a really tall task ahead..didnt smith set the record? swear i seen him say he was just over 3k some where..not sure though..me i would have a th400 in it an shoot for 3k with driver..
As for the intake,why not spend the money right..your trying to go for a record with a car thats extremely heavy an has a trans not ment for drag..you said you want to get the best power you can n/a before you spray it..why go with a intake that may only work well with your mid lift numbers? an before people jump on me yes fast intakes are nice intakes but you aint going to see one of them on a badass all out piece so why settle for something u dont think would be a terrible combo.
if your worried about longevity with it then i would just keep spraying what you are add some good heads to it,fix the converter and do some weight reduction..if i was going all out for the record with a sbe deal i would be going in full an well knowing this bitch could send a rod threw the block on the first damn lick once i felt i had a tune for a big big hit.
