Cam recommendation?
(did in my car too) good bolt ons stock head LS1s. I did a thread "cam only setups making 400wtq" checvk that out. The others listed max 410-425whp and 385-395wtq.also check out the steetsweeper cam 236/240, I loved that cam. Alot of guys that ran it do to. Drives great and I made 425/393
a good tune is a must, see what yout tuner likes. Theres a Lot of good cams out there, a poor tune wlil make any of them suck
I would also expect the T-Rex to make the highest numbers out of those as it's simply the biggest and has the most overlap. Not hating or attacking, just commenting.
http://www.tickperformance.com/tick-...1-ls6-engines/
They are both great cams that I think you will really enjoy either way you go. Since you have a 4000rpm stall, any power gains under that rpm will be pointless, because at WOT you will never see that RPM. I think the V.2 is your huckleberry.
Just keep in mind with the V.2 or the SNS Stage 3 if you go to an aftermarket head with larger than stock valves, or with milled heads you will need to fly-cut your pistons. I believe TSP sinks their valves in the seat a little more for some added P to V so you could run their heads in that regards and gain some P to V with added compression or larger valves, or you could go to a PRC 227 or TEA TFS head that has a 13.5* valve angle so you can retain stock P to V with a larger intake valve and added compression. If you got an aftermarket casting that is cast with a 64cc chamber you'll gain compression and valve area while keeping stock P to V so that's something to think about in your build preparation. The SNS will drive slightly better as it opens the intake valve just a little later than the V.2 which puts the intake valve opening at a more favorable crank angle in regards to cylinder fill and drivability. The V.2 still drives pretty nicely for a large "donkey dick" cam.
It all goes back to if the cam is right for the application it doesn't matter if it's shelf or custom. You're really splitting hairs that aren't going to make a difference in the end result.
