Oil pump?
Old Jan 18, 2013 | 08:08 PM
6togo's Avatar
Default Oil pump?
Are there any oil pumps that clear a double roller chain besides the Slp pump? Anyone know who the Slp pump is made by i heard Mellings is that right?
Old Jan 18, 2013 | 08:16 PM
Sales1@Texas-speed's Avatar
Our Texas-Speed ported LS6 pumps clears double rollers.
Old Jan 18, 2013 | 08:20 PM
6togo's Avatar
Are the ported pumps high pressure or volume?
Old Jan 18, 2013 | 10:30 PM
JPH's Avatar
JPH
Schumanns racing pumps do I believe.
Old Jan 18, 2013 | 11:12 PM
6togo's Avatar
I seen someone mention sinister something or another was making clearanced pumps but i can find the info on them.
Old Jan 18, 2013 | 11:53 PM
chrisfrost's Avatar
There was a thread on here that a guy posted suggesting Schumanns oil pumps so I checked Them out and it turns out that Their pumps don't use a piston type over pressure relief valve but rather a ball bearing type which would be very difficult to get stuck and it should work with a dbl chain .
Old Jan 19, 2013 | 06:04 AM
6togo's Avatar
I looked at their pumps and the one stated with shims it clears the double chain and front cover.
Old Jan 19, 2013 | 03:00 PM
High pressure.
Old Jan 22, 2013 | 08:01 PM
6togo's Avatar
So anyone running the Slp pump with out issues or double clearance problems?
Old Jan 22, 2013 | 08:06 PM
FormulaTA327's Avatar
i believe Fear LS is running a slp pump with JP performance double roller timing set, could ask him how good it fit, that setup is what i plan on getting they are supposed to clear and from what i heard slp pump is a ported melling pump
Old Jan 22, 2013 | 09:27 PM
6togo's Avatar
I read on hear it was a melling but could never confirm that! I will shoot Fear LS a PM.
Old Jan 23, 2013 | 09:03 AM
6togo's Avatar
Chatted with Fear LS about the Slp pump said it was all fine no issues anyone else using this pump without problems?
Old Jan 24, 2013 | 10:31 PM
6togo's Avatar
Ttt!!!
Old Feb 13, 2013 | 10:06 AM
grim_ls1's Avatar
I'm running a slp pump with a comp cams double roller with no issues. No need to use shims cuz its built into the pump.
Old Feb 13, 2013 | 10:54 AM
JakeFusion's Avatar
Super Hulk Smash
Synergy has a ported LS6 that clears as well.
Didn't know the TSP was pre-clearanced. That's cool.
