Random Misfires on Cammed Trans Am
Old Mar 18, 2013 | 02:31 AM
  #81
zrultima's Avatar
Originally Posted by Austinma62
sounds like you have some valve train issues
Well i would of thought so too but car runs fine out of nowhere it would start acting up a gm mechanic stated that what you hear is regular for an ls1 especially with 180k miles well now its 190k. I miss my cj i shouldnt of done the trade with the guy im just so pissed off as if it ever does blow up i wont have a way to get to work
Old Mar 18, 2013 | 02:53 PM
  #82
99Bluz28's Avatar
I'd have the O2 wiring checked from the pcm to where the O2 cables plug together, and also check the grounds on the back of the heads.
BTW, in the video is that exhaust smoke I see on the passenger side?
I'd also remove the passenger side valve cover and check for a loose rocker mount bolt/s and rockers that are loose from the factor bearings giving out.
I know having difficult to find issues takes all the joy out of owning a F-body, it can be really frustrating!
Good luck, an I hope you solve the problem soon so you can start enjoying it!
Old Mar 18, 2013 | 06:08 PM
  #83
zrultima's Avatar
The exhaust smoke you saw is of some oil i dropped down when i filled her up when i got home nothing to worry about. What i was thinking is to replace both 02 sensors woth corvette sensors since they are longer. I heard good things about bosch but then again ac delcos are from factory. If the rocker arms are worn out replacing all of them would it be an easy task? I am definetely trying to get to the root of the problem seller wont help and i left him a nice rating for the trouble he has caused.
Old Mar 18, 2013 | 08:31 PM
  #84
99Bluz28's Avatar
The rocker trunions (bearings) aren't hard to change, that's most likely all you'd need to do with them.
With the 97-2003 corvette rears O2s you'll want either BOSCH Part # 13111($48), ACDELCO Part # 213810($61), DENSO Part # 2344617($41), NTK Part # 21537($47), or DELPHI Part # ES20003($49). All prices are each.
The ACdelco and Bosch sensor covers look the same, and the Denso and NTK sensor covers look the same.
Old Mar 18, 2013 | 09:49 PM
  #85
zrultima's Avatar
With the 97-2003 corvette rears O2s you'll want either BOSCH Part # 13111($48), ACDELCO Part # 213810($61), DENSO Part # 2344617($41), NTK Part # 215379$47), or DELPHI Part # ES20003($49). All prices are each.
Thank you Blu ill probably buy both this weekend as far as the rockers can i buy the trunions separately or can i buy the rockers as a set alonh with the bearings
Old Mar 18, 2013 | 11:00 PM
  #86
99Bluz28's Avatar
Most just buy the trunions separately($140), but some sponsors do sell them installed($430) in factory rockers
You should have no problem finding a friend or shop to press out the old then press in the new.
Hell, ship the upgraded trunions and your (serviceable) rockers to me, and for $20 + the cost to ship them back to you, I'll remove/install them with my small arbor press.
http://texas-speed.com/p-1088-texas-...m-package.aspx
http://texas-speed.com/p-361-cohemp-...s-engines.aspx
Old Mar 20, 2013 | 08:43 PM
  #87
zrultima's Avatar
Ron the car ran like **** today i could barely keep up with highway traffic and the ses light was flashing for a few minutes no strange noises or knocking sounds
Old Mar 20, 2013 | 09:11 PM
  #88
ds98formula's Avatar
after flashing did it come on solid and stay on?
Old Mar 20, 2013 | 09:31 PM
  #89
zrultima's Avatar
Yes it did but the codes stay the same
Old Mar 20, 2013 | 09:51 PM
  #90
did you ever change o2's like you said you where going too? when the light came on solid did it run better?
Old Mar 20, 2013 | 10:00 PM
  #91
zrultima's Avatar
It did run better once it stopped but not as best as it could when cold
Old Mar 20, 2013 | 10:07 PM
  #92
zrultima's Avatar
I havent bought them waiting till the end of the week
Old Mar 20, 2013 | 10:23 PM
  #93
When its cold and when the light goes solid it is in open loop. This sounds like o2's to me. Car will run good cold till it gets to 140degrees then will go to closed loop and run like crap when trying to use the o2's to run. Then the computer will see that it is not working and kick it out of closed loop again. I would start there also look for any exhaust leak befor the o2's that could be giving the o2's a false reading. If that is not it then I would have a tuner look at the tune and see why in closed loop it is running poor
Old Mar 20, 2013 | 10:46 PM
  #94
99Bluz28's Avatar
FYI, even if you change the O2 sensors you might still have the same issue, that's why I'd recommend verifying that the O2 wiring from the PCM down to the plugs where the O2s plug in are good. If you have to take it to a shop that specializes in electrical diagnostics I'd do it.
Old Mar 21, 2013 | 08:10 PM
  #95
zrultima's Avatar
Ill definetely look into the wiring to the pcm i hope the proble that simple
Old Mar 23, 2013 | 03:19 PM
  #96
zrultima's Avatar
My store in nc doesnt sell acdelco or the bosch sensors at all not even the warehouse
Old Mar 23, 2013 | 04:36 PM
  #97
zrultima's Avatar
I bought ntk downstream sensors the same.one.the vettes have
Old Mar 28, 2013 | 06:59 PM
  #98
zrultima's Avatar
Well guys i sswapped out the passenger side o2 sensor with tje ntk looks like it had a bosch sensor once i took off the bosch it was covered in black soot. The car is now running fine but i havent drove it long enough to see if it has fixed the problem. The ses light did turn off once i switched it out and drove around for a bit. I will keep everyone updated but hopefully this fixes it there is still some whote smoke coming out on idle smells like gas
Old Apr 8, 2013 | 09:20 PM
  #99
zrultima's Avatar
Just an update for the folks replace the o2 sensor on the passenger it has not acted up since then at all. A code popped up though only for the passenger side stating slow response from bank2 sensor 1 which is the one i replaced. I replaced it with a ntk corvette sensor any ideas on fixing it kind of strange its only on the passengetlr side.
Old Apr 9, 2013 | 12:13 AM
  #100
99Bluz28's Avatar
Good to hear, sounds like you finally got it fixed!
