Anyone running a Tick Street Heat cam?
Old Jan 23, 2013 | 07:32 AM
Sales@Tick's Avatar
Originally Posted by stroked383HSR
close enough....post up! difference?
Slightly lower peak horsepower and torque figures, will peak in regards to peak HP/TQ RPM about 100rpm earlier than the Stage 2 and will have slightly less overlap so it will sound just slightly milder, but it really isn't enough of a difference that you'd ever be able to tell power, sound or drivability wise.
The car had 243's milled to 11.0:1 CR, valve job on the stock valves, ported FAST78 with a 85mm TB, Ebay 1x3/4" headers, 3.5" merge, 3.5" cut-out into a SLP dual/dual exhaust set-up. Ignore the peak torque figure as it was due to a spike in the graph as you can see. It made 444rwhp/414rwtq with that cam which IMO for a "223" cam is very impressive! 3500rpm it has made 380rwtq and by 3800-4000rpm its made 400rwtq.
Old Jan 23, 2013 | 09:02 AM
Sales@Tick's Avatar
Just got this last night from member "FEAR LS" as he finally wrapped up his H/C install with the SNS Stage 2 "Torque Max" camshaft.
He has a TSP ORY and a Borla adj. cat-back, enjoy!
Old Jan 23, 2013 | 10:08 AM
stroked383HSR's Avatar
I been wondering what it will sound like...hell yeah!>...im ready for the swap! thanks for the vid!
Old Jan 23, 2013 | 11:21 AM
Blackpanther99's Avatar
Very nice Martin. Thanks for the graph post, idle sounds real good!
Old Jan 23, 2013 | 01:38 PM
Sales@Tick's Avatar
I am too! I want to see what it does on the dyno! Your car and about 3-4 others will be wrapped up shortly so I'll have some results from several different set-ups with different parts to show people when they ask the next time.
I love the idle. It's nothing so choppy that you couldn't take your mother or wife out to lunch or dinner in, but it's choppy enough to make people say, "I'm not messing with him that sounds like a big cam!"
Old Jan 23, 2013 | 02:36 PM
Camaroking1996's Avatar
That cam sounds awesome!! Any dyno sheets on it?
Old Jan 23, 2013 | 04:09 PM
Sales@Tick's Avatar
The dyno graph I posted about 5-6 posts ago shows a dyno graph for a 223/235 110+3 cam which is nearly identical to it. The 227/235 SNS Stage 2 will make a little more power than the one in the graph, and peak slightly higher, but that's it.
Old Jan 24, 2013 | 10:53 PM
Martin,
I was checking out the pictures of the head...look inside one of the exhaust ports. There is a piece of packing lodged inside stuck to the valve. Might wanna get that out before install.
Old Jan 25, 2013 | 08:48 AM
Sales@Tick's Avatar
Martin,
Got it!
Old Jan 25, 2013 | 08:56 AM
FEAR LS's Avatar
That's one healthy sounding beast up there. #MyShit lol
Old Jan 25, 2013 | 10:40 AM
yes sir it is...
I'll know and hopefully feel the same in about a week or so....if it sounds like that I'll be more than happy!!
I have the same exhaust with an electric cutout in place of the plate. But i keep it open at all times.
so we will see
Old Jan 25, 2013 | 12:33 PM
  #32
Rise of the Phoenix's Avatar
Guys, I will make sure to post up my numbers once I get the build done. My setup will include AFR 205cc heads, milled to 60cc and the SNS Torque Max 2 cam (227/235 110+3 LSA). I've already got Stainless Works Long Tube Headers, Texas Speed True Duals and a SLP Lid. I will be sticking with my LS6 intake for now as well. I'm hoping this setup is good for around 440 rwhp and over 400 rwtq.
Old Jan 25, 2013 | 12:40 PM
  #33
Im jealous of your AFR's
Im hoping for around the same with my setup....
Old Jan 25, 2013 | 12:43 PM
  #34
What heads do you have, or are going to run?
Old Jan 25, 2013 | 12:46 PM
  #35
in my sig.
Texas Speed PRC 2.5 5'3's
I dropped my car off yesterday with Tick...for the head and cam package install.
Old Jan 25, 2013 | 12:51 PM
  #36
in my sig.
They should work well with that cam. Can't wait to see the results. Is Tick doing the tune too?
Old Jan 25, 2013 | 12:55 PM
  #37
yeah they are doing it all. install and tune.
check them out on facebook with the link in Martins sigs.
Old Jan 25, 2013 | 12:59 PM
  #38
Are your heads milled at all?
Old Jan 25, 2013 | 01:00 PM
  #39
standard....63 or 62...cant remember. should put me right at 11 to 1
Old Jan 25, 2013 | 01:02 PM
  #40
Nice. My heads are at 60cc, so the PTV clearance is going to be on the tight side, but should clear fine.
