Budget head choices
- Ai HCR 219's
- PRC st 1 LS6's
- PRC st 2.5 5.3's
Obviously I would like some AFR 210's, TF 215's or PRC 227's but not in the wife allotted mod budget, lol. So pro's and cons of my selections? Or firsthand experience with them? B to B dyno or track times would be awesome but I doubt people switch from one budget head to another very often.
Thanks Wes
- Ai HCR 219's
- PRC st 1 LS6's
- PRC st 2.5 5.3's
Thanks Wes
I am totally sold on Ai. Have read many results from satisfied people. But when in a budget standpoint I'm really eager to get the most for my dollar. I mean there are like 5 well known heads in the 1k-1.3k range. The question is how much of a difference between them.
And predator, I may end up hitting you up for a cam recommendation. I've been from the 228r as the smallest to the Polluter as the biggest on my decision making process. If you want to give advice ill give more info.
Can't go wrong with TEA either as they do great port work also. The only thing I don't like about the TEA heads is that they use a 2.04" intake valve on their stage 2 heads which eats up P to V clearance. For guys that are willing to fly-cut it's a non issue, but for guys that can't fly-cut or don't want to...it is. Now their stage one heads use a factory intake and exhaust valve with the same port work that the Stage 2's have. Also a good option is Livernois, but they are a little more pricey than AI or TEA.
https://ls1tech.com/forums/dynamomet...o-results.html
https://ls1tech.com/forums/dynamomet...-gm-5-3-a.html
Although the only bad part of doing cam only is you have to swap springs on the car or take the heads off anyway
We currently have over 150 sets of heads in stock so odds are we will have a head to meet your needs in stock & ready to ship
http://www.texas-speed.com/p-3515-pr...ral-heads.aspx
http://www.texas-speed.com/p-1391-pr...ted-heads.aspx
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
