DIY LS1 Head Porting at home can Help
#41
1 Post
Fun stuff, thanks.
I have ported SB and BB Chev heads with guidance from a pro in the past.
Also ported a few Olds Quad 4 valve heads...those thing flow! I had them measured. In fact, they flowed 280 intake and 210 exh at .400 lift!
I took the easy way out and bought AFR's for my LS1, But I have the stock 853 in the garage. I should play with them some day.
Ron
Ron
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
#43
1 Post
Thanks! I've been considering 2.02's as well. You'll get better flow with them for sure. I dont know how much more it'd improve with a boosted application. It seems Boost usaully makes flow detail not as critical.
#45
1 Post
I feel that I should also give more detail on these heads just to be clear. They are 862 5.3 heads home ported, milled .030" and I used 2" LS1 valves. The engine is a 2000 and has 165k miles on it. Bore didnt have much cross hatch. Bout polished. lol dished piston equals to about 9.9:1 compression.
I think the heads would show a lot more with a larger cam that could use the flow.
#47
Anyone have any info on a stock ls6 vs a home ported Ls1? Seems it would favor the Ls1 being a smaller port even ported and flowing slightly more intake and a good bit more exhaust. I know the combustion chamber in the ls6 is better but would think that has more to do with mpg/timing than raw power.
#49
1 Post
Good luck on the build.
#50
1 Post
I also have pics of stock LS6 and stock LS1 head ports cut in half so that you can see the port shape.
#53
Honestly peak power is something that sellers use on the intrawebz to get people to buy. I think power across the whole range and under the curve is what matters since that is what you feel when you drive.
#55
1 Post
Guess I'll go back and read the mag now since my 15 min is over.
#58
From what I understand its a way to gently direct that column of air not just through the bowl and valve but on through the chamber and down the cylinder. I havent read the article yet, but this seems common on just about any inline 2 valve arrangement. Will read the article eventually...
#60
Yeah we need a head porting sticky!!
And to agearheadlife- great info and its awesome somebody took the time to do this! Im no expert but somebody might have said this but ive also been told you do not want to slow the velocity of the air down by porting to flow more cfm. And the gmhtp article is a perfect guide!
