Urgent Answers Needed: 408 Build
Couple quick and dumb questions for guys:
1: where are the intake valves on LSA heads? I believe that they are the first valve in the cluster from the front of the engine to the back.
2: what valve lash or gap do i need between the valve tops and the rocker? Im running stock LS3 rockers and my cam is a 236 intake and 242 exhaust 114 LSA + 3.
3: what is valve preload?
Thanks in advance for ur help. This is my first LSX build.
preload is the distance the lifter plunger is depressed into the lifter body.
I may not be thinking correctly, but if your building the engine, how did the builder measure your pushrod length before the heads were on the car??
