Why so few 366 strokers???
Old Jan 12, 2008 | 10:13 PM
  #41
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
Originally Posted by LSXS10
If i use a 6.0 iron block and an offset ground crank what rods and pistons?? What is the rod jornal diam. how much do they cut? Honda rods??? custom pistons?? Sombody let me know some info....
Ok, I just did a good hour and a half reading about this so I'll regurgitate what I just read.
Stock crank = 2.1 inch journal = 3.622 stroke
2.0 inch journal = 3.71 - 3.72 stroke
1.888 inch journal = 3.822 stroke
You need to find rods that are in that journal size. You'll also need custom pistons. If you know where to search you can find the rods rather cheaply. From what I read having a crank redone ranges from $150-500. You need to make sure they put a good radii on it to help with the small journals. All of what I read sounded rather positive.
Old Jan 12, 2008 | 10:35 PM
  #42
LSXS10's Avatar
Well i was going to build a 370 with a stock crank ....I will have to do some math but what about a 408 " 4inch stroke" piston, find a longer rod not sure in the lenth yet and then offset the crank to match , it s going to be close to a 6.5' rod...Let me do the math
