AI 226cc vs 232cc Heads
Bigger valves with the same flow numbers means less velocity at the throat area. Smaller valve with the same flow means more velocity at the throat area. This normally equates to a higher torque figure which with the proper cam timing equates to a larger horsepower figure and a faster car in general.
