Finally pulling the trigger on parts!
Though I did get one out. I just put the punch on it and hit it in the center of the bore and it came right out. The other. I'm on about 1700 whacks and it's still there.
Enough for it to wiggle out then you can grab it with some needle noses..
I do have one relief that cut a little deeper than the others, and it's getting pretty close to the edge of the piston. It's still fairly shallow there, and I know that's the thickest part of the piston, but I'm going to take extra care when I sand it smooth to reduce any hot spots there since it's close to the ringland.
Tomorrow will be me finishing the cuts on the exhaust side. It should go fast since I was able to run through all 8 intake valves in about 45 mins tonight. Practice helps, I suppose.
How fast were you spinning it with the drill? I don't think they're supposed to be spun too fast. Were the chips coming off the pistons blue?
I already told her she can have a new car. I'm going to sell off my Nissan and her Toyota and buy her something better.
I was trying to convince her to get a Jeep SRT-8. That did not go over well for some reason.
Of course, if I could get her into a Mercedes AMG...
Why did I marry a non-gearhead woman LOL.
What the hell, Jake! Throw caution to the wind like you have with everything else!
Just show up with it!
It's coming along. The number 1 piston is not an optical illusion. The bottom of the cut is actually lower. That's because I ended up going .072" deep there vs the .062" deep I had it set to. Go figure. I guess I didn't have the lock nut flush on the feeler gauges. But, I don't mind going slightly deeper. I'd rather that than being too shallow and having a valve crash into the piston.
nice!
