Finally pulling the trigger on parts!
Old Nov 9, 2013 | 05:48 PM
  #701
RezinTexas's Avatar
I put a light copper spray on my cometics, had no trouble sealing
Old Nov 9, 2013 | 06:23 PM
  #702
JakeFusion's Avatar
Super Hulk Smash
Copper spray is very tacky. I plan to do it even tho they recommend installing dry.
Old Nov 9, 2013 | 09:21 PM
  #703
JakeFusion's Avatar
Super Hulk Smash
Also, I have been wavering on the S60. It's really big and heavy. And behind an A4, I don't know if I need that much rearend strength.
Moser 12-bolt is goofy, so I've been looking at the Strange 12-bolt with an Eaton 33-spline Posi w/4.11 Gears and a PST 3.5" Alum driveshaft with the Cryo 1350 U-Joint.
Would that would be fine to 600rwhp in an A4? I get to keep 3" axle tubes (for the Strano swaybars) and keep weight down compared to the S60 for handling purposes (I still want this thing to take a corner to some degree). The best would be a Moser M9. But it's very expensive for what I plan to do.
Any thoughts?
Old Nov 9, 2013 | 10:06 PM
  #704
Blackbird-WS6's Avatar
i know someone that has broken his Strange 12-bolt 2 times forsure, maybe 3 times. his car is just an auto with a cam and full bolt ons.
i ran a 9inch and had no problems with it. i think next time i will go with the s60.
Old Nov 9, 2013 | 10:09 PM
  #705
427zm's Avatar
What are weight differences?
Old Nov 9, 2013 | 10:20 PM
  #706
JakeFusion's Avatar
Super Hulk Smash
S60 straight up is like 25lbs heavier. Once you factor in the aluminum cover for the 12-bolt, it's more like 30lbs? So, not insignificant.
And breaking a rear that many times is strange. Especially with an auto. Is it the Eaton that's failing?
The aluminum Spool with gundrilled axles weighs only 140lbs total from Strange. I know a Spool is counterproductive to turning, but that just goes to show you how light you can make them. That's like 80lbs less than an S60. And most folks have a hard time breaking a 12-bolt spool.
Old Nov 9, 2013 | 10:28 PM
  #707
ring and pinion everytime. was set up from Strange already and still broke.
Old Nov 9, 2013 | 10:32 PM
  #708
JakeFusion's Avatar
Super Hulk Smash
That makes me sad. Mainly cuz stepping up to a Moser 9" costs way more than a Strange 12-bolt. That leaves the S60... which is actually cheaper than the 12-bolt right now.
Old Nov 9, 2013 | 10:41 PM
  #709
i rather deal with some more weight and have a strong and cheaper rearend then pay more for one i need to worry about. thats like having the 10bolt lol
Old Nov 9, 2013 | 11:00 PM
  #710
97camaro383's Avatar
agreed! Thats why I went with the S60 and I couldn't be happier.
Old Nov 9, 2013 | 11:29 PM
  #711
JakeFusion's Avatar
Super Hulk Smash
Also, I forgot about the freight fees Strange adds to their axles. Moser 9" isn't actually that much worse with a 31-spline TrueTrac when shipped... Hmm. Still much more expensive than an S60 tho. But a 9" would be plenty strong.
Old Nov 10, 2013 | 02:25 AM
  #712
maxpower_454's Avatar
I never heard of someone breaking a strange 12 bolt but I guess I did now. I find it extremely hard to believe tho especially on that power level with an auto. He may have gotten a lemon.
I was leaning toward the 12 bolt because of weight like Jake mentioned and also because every Moser 12 bolt owner I encounter says their rear got loud after like 10 passes.
9" rears rob a good bit of power (around 5%) though so consider that when balancing the weight difference between an S60 and a 9". I'm still undecided between the strange 12 bolt or the S60. I was contemplating a 8.8 build and also a 9" but I know I won't be able to sleep at night if there's a F@rd part on my car, haha.
Old Nov 10, 2013 | 02:43 AM
  #713
Burken01's Avatar
Mightymouse ran a moser 12 bolt, and we all know how fast that guy was going!!
Old Nov 10, 2013 | 09:52 AM
  #714
JakeFusion's Avatar
Super Hulk Smash
That's all very true. The S60 also eats up power too. Hmm. I'll worry with it when the 10-bolt blows up. lol
Old Nov 10, 2013 | 11:16 AM
  #715
Coonass350's Avatar
From what Carl @ CRP told me the S60 doesnt eat much more power than the Moser 9" if any. There was an article he showed me awhile back that did a comparison between the 12 bolt, s60, & 9". I am going with the S60 for the fact that it is strong as ****, and is quite a bit cheaper than the Moser 9". It might be a bit heavier but Ill take the hit on the weight for the price difference. Just my opinion
Old Nov 10, 2013 | 12:05 PM
  #716
JakeFusion's Avatar
Super Hulk Smash
Lol.
If I knew I was going turbo down the line and was looking for 800+rwhp, I'd do the S60. Who cares at that point how much power it eats - you need strength. But at 480rwhp? Eating 5-6% of that is a big deal and that's about what an S60 eats per what I've seen in GMHTP. The Moser M9 they tested it against ate like .4%... And it's lighter than a 10-bolt. And super strong as well. But also very expensive.
Strange 12-bolt might give me the best combination of strength without too bad a weight or power penalty at a price I'd actually consider.
Old Nov 10, 2013 | 01:28 PM
  #717
Lol.
This article shows that a dana 60 (S60) eats pretty much the same as a 12 bolt. A 9" eats more.
http://www.carcraft.com/techarticles...p/viewall.html
I never saw the one from GMHTP. Can you post the link?
Old Nov 10, 2013 | 02:25 PM
  #718
JakeFusion's Avatar
Super Hulk Smash
http://www.gmhightechperformance.com...r_m9_rearends/
3.5% to 1%... and the M9 was in a more powerful car losing less.
Old Nov 10, 2013 | 02:27 PM
  #719
A.R. Shale Targa's Avatar
For a few years now what some dirt (street stock) and NHRA (super stock)
racers have been using is the 9" housing with the 12 bolt third member.
The weaker yet less power robbing pinion location of the 12 bolt gearset plus
having the gears ni-chem coated tends to reduce friction (cooler fluid temps)
and frees up some rwhp.
Old Nov 10, 2013 | 02:43 PM
  #720
JakeFusion's Avatar
Super Hulk Smash
Interesting concept. I'll play around with it some more and see how the budget looks when the 10-bolt explodes. lol
Hell, if the budget affords an M9 or MWC Fab 9 then I'd do that. Actually, when I priced out the M9+TA vs a Moser 9" + BMR TA and 4L60E Relo bracket, the difference was only a couple hundred bucks. In case you can't tell, I'd really like to have the M9 and usually I can talk myself into blowing my budget to get what I want.
Anyway, the valve reliefs were cleaned up today. All are pretty much spot on depth wise after I went back over a few with the cutter. Then I sanded any rough spots and cleaned out the reliefs with some B-12 chemtool. Very smooth to the touch now.
Pics:
Driver's side
Passenger's side
