550 rwhp possible?
Stroker bottom end 2k
Killer heads 3k
valvetrain/cam 1k (not going to do it with your cam)
intake and fuel 2k
You're going to need to beef up your drivetrain to handle the power and rpms, so 10k is most definitely what you will need to spend.
I doubt you will be able to get 550rwhp out of a 383 unless its completely unstreetable. 500rwhp through a 6spd and a 10 bolt would be feasable.
About the only advantage to the 383 is keeping the aluminum block, it is sorta nice not to have the extra 100+ pounds on the nose.
