My 347ci build
Changed up my plan of action and decided I wanted a cleaner chassis to swap this engine into instead of having to basically rebuild one. May still do it just for the sake of learning how to work with metal but it won't be used for this project. Ended up picking up a 99 M3, southern car, no rust. Needs some TLC but in general the exterior is very clean.
I've been spending some time shaking the suspension/brakes/clutch on this thing down and plan on enjoying it in its current form for the time being. (Sorry for the large picture).
Lol let them, I don't care. I'm a car fan first that just happens to drive old bmws. It doesn't take a rocket scientist to realize that your money is better spent on things other than $2500 cam / intake / tune kits that result in little more than a 20 whp improvement at peak on these engines -- and you still have no bottom end. Unless you're going F/I, any mods are a waste of time if you're looking for power. Given that I wasn't interested in F/I my choice was pretty obvious. The stock engines in these things are awesome for what they are though - with a chip they redline at 7.5k and sound glorious the whole way there
Your setup clearly has advantages. BMW engines are unreliable, underpowered, have a weak aftermarket, and are difficult to work on.
Does the M3 engine still run? Is it worth anything?
But the engine in the M3 still runs like a pissed off ape. Honestly not sure what condition its in but I could probably get $2k or so from it as a dropout. A lot of non-m E36 and E30 guys like to swap these motors into their cars.
A lot of guys do the 2J swaps as well, though they aren't as popular as LS swaps.
That is one of the very few rides that scared me in my life.
Picking back up with verifying lifter preload with the sample pushrods.
Today I picked up where I left off last time with pushrod length / preload. Initially I was having problems getting repeatable measurements, just double checking what I got last time. It might be obvious, but it was a lesson for me - you're wasting your time if you don't fully torque the heads down before measuring. I had them "snugged" before not wanting to fully torque down on new gaskets, not thinking there would be a big difference, but boy was I was wrong. The results changed significantly, so I measured all over again.
Here are the new measurements if anyone cares - you can compare them to the ones I posted previously and see the difference for yourself.
With that out of the way I moved on to lifter preload. Last time I was having issues with indicator drift as I was tightening the rockers down. The tip would kind of float around and cause measurement error / prevent me from getting anything reliable or repeatable. A very touchy process to say the least. To try and fix it I bought another indicator tip and ground / polished it to more of a point. The tip would nest into the oiling hole on the pushrod side of the rocker and (hopefully) prevent it from drifting around as I tightened things down.
I only got to measure one valve tonight, but did the #2 intake with the 7.700 pushrod from Trend I have. From my measurements, it needs a 7.664 for zero lash in this spot - so theoretically putting a 7.700 in there should give me 0.036" of lifter preload IF my measurements are comparable to the way Trend measures their stuff.
Repeated multiple times and got between 0.036-0.038". With all the stackup and potential sources of error going on I'm pretty happy with that. Note that this is not my desired preload, however - I want between 0.025-0.030"....I'm simply using the Trend pushrod as a "witness" to my methodology. I just hope the rest of them that I can check with this pushrod follow that closely.
Thanks for tuning in...more to come soon.
-Chuck
Cyl 2 intake: Expected - .037. Measured - .038.
Cyl 4 intake: Expected - .030. Measured - .020.
Cyl 6 intake: Expected - .040. Measured - .023.
Cyl 8 intake: Expected - .022. Measured - .015.
I'm suspecting that maybe my fixturing might be causing me some error.... the indicator tip may not be inline with the pushrod completely but I'm doing my best to make it that way with what I have. For those of you who have measured lifter preload, how did you afix your indicator and how close were your measured values to what you were expecting?
