My 347ci build
Just a thought here as I am no expert, just giving what I think is experience. It looks like you are making your measurements with the valve springs (and not checkers) installed. In my opinion this is good.
In my experience when measuring installed preload directly the hardest part is to determine the zero lash point. The two biggest sources of error in my experience were getting the pushrod exactly where it needs to be in the lifter plunger cup and depressing that plunger when wiggling to determine the zero point. What I ended up doing was prefilling the lifters by repeatedly heating and cooling them in oil on the stove, rotating them every once in awhile. I used a thermometer to keep the oil <220 ish. As you well know this will push the air out on the heating step and then draw oil in on the cooling step. This makes our sweet Johnsons rock hard. Er, you do have Johnson lifters too, right?
Second I just put a dab of oil in each lifter cup, that seemed like it may have helped the pushrod to find home. I'd try and wiggle the puhrod into place as I neared the zero lash point as well. With the rock hard lifter and the rock hard valve sping the zero points were repeatable within a few thou for me.
So YMMV and I may be forgetting something, but hopefully that was helpful.
The way I was thinking, valve springs >>>> lifter plunger springs, so I wanted to try it without filling em up so I don't have to wait for the oil to bleed out and get my reading, but I'll definitely try the dab of oil to help it find home.
Btw - I'm assuming you filled the lifters with oil prior to install?
Hoping for some forward progress this weekend guys. I'm starting to question whether or not I really need to be as **** about this, but I'm enjoying the challenge of trying to be as precise as I can (I'm sick, I know). I'll summarize this whole process into a single post of what I've learned from this whole measuring process once I have the results I'm looking for. I imagine it's kind of hard to follow at this point without going back a few pages.
And Chuck, I am sure you are a little frustrated about it but keep pluggin man, you'll get there. Look how far you've gotten so far. Seems to me that this may be as tedious as setting up the bottom end clearances,etc
. Could be wrong though, Ill find out myself in a few months
"Waiting" for leakdown is a red herring IMO. I believe we're talking about rates of 100 thou in 30 to 60 seconds with ?50? lbs of pressure, there is an industry standard, maybe Randy can chime in. You just need to tighten slow and careful and you wont even notice the 10ish seconds it takes to bleed to your preload.
First off let me say that getting accurate and repeatable numbers was extremely time consuming. I learned that the bulk of my error was in my fixturing and in my hands. What I mean by that is if you don't tighten them down exactly the same way each time or if you let the rocker pair twist you will get different numbers.
If you're doing this at home, save yourself some trouble and pick up one of these from harbor freight for $13. It allows you to manipulate the indicator any way you want and really dial it in to being in alignment (or close) to pushrod travel.
Here's how I'm fixtured up.
Checking the intake valves on the passenger side again, here's my expected preloads based on the difference between my zero lash length for each valve and my test length of 7.700".
Cyl 2: Expected: .035
Cyl 4: Expected: .030
Cyl 6: Expected: .040
Cyl 8: Expected: .022
Close enough. Repeated measurements show that I'm within +/- 0.001", which is the same tolerance that the pushrods are supposed to be manufactured to. About as good as I could hope to achieve at home in my basement I think.
So this was kind of a really long, roundabout way of making sure my measurements give me the preload I'm expecting when the real pushrods are installed in the engine. Impossibly tedious and often made me hate life while trying to figure it out, but it was a necessary step (imo) given that I macgyver'd a means of measuring the gauge length of the pushrod checker directly. Now all I've got to do is order the proper lengths from Trend and hope they cut them to the right length!
If anyone has any specific questions on any of the setup or anything ask away, I'm happy to answer.
Anyway, figured I'd share my measurements
Looking at the "theoretical preload" column, I was able to hit my .025 - .030 target pretty consistently. Some small adjustments needed but I'll be able to bring in the outliers by adjusting my rocker shims slightly.
That being said, I've starting looking into catch cans. There's a lot out there, can anyone recommend a good one?
I've been working on a coolant crossover setup for the engine - opted to piece together my own kit so that I'm sure it works with a fast 102, similar to the one nitrous outlet sells. Hopefully I'll have some pics to share this weekend.
I'm using the wegner adapter blocks you can get for ~$5 a piece and 1/8 npt to -4an adapters in various orientations.
Tight here at front driver's port
And here at rear passenger's port
I cured those problems by cutting some threads off the adapter fittings to reduce the overall height and shaving the corners of the intake some with a bearing knife.
The manifold to tie them all together will be here at the front passenger port.
I opted to do all the lines in 1/4" stainless hardline, trying to keep everything as clean as possible and avoid ratnesting everything with hoses. Waiting on bending and flaring tools but I've been playing with the routing using coat hangers for mock up.
Hopefully more to come this weekend.
Keep up the good work brother.
