2004 LM7 cam options
Advice would be cool from you all of you fine people at LS1tech that know more than I do. lol
Second if your gonna do a cam swap , do a an actual aftermarket cam not the ls6 your gonna wish you went bigger later on (been there). If your not looking to go crazy i would pick up a comp cam XR265HR , which is a 212/218 on .522/.529, this will allow you to use the cheap ls6 valve sprigs, but no matter what cam u need to do hardened pushrods. If you wanna go slightly bigger the 220r from TSP with the 580 lift is an EXCELLENT cam for the 5.3l , if you go on the truck forums youll see many people get great numbers from them
What injectors you use depends on the fuel rails you have and wiring harness.
A cam swap should include upgraded valve springs and hardened pushrods. Most vendors have cam kits with everything you need. A 2002+ LS6 cam would work, but there are better cams available. The 212/218 Comp Cams that was mentioned is popular with the 5.3 truck guys because it has lots of low end torque and you can use a stock torque converter. Since you are not as heavy as the trucks and are using a manual trans, I'd go a little bigger. The Texas Speed 220R would be a sweet choice.
http://www.tickperformance.com/tick-...1-ls6-engines/
