is it worth it. fast90 to a new 92
Old Feb 17, 2013 | 07:39 AM
SKULL's Avatar
Default is it worth it. fast90 to a new 92
i have a fast 90 on my vette currently just a bolt on car. im planning on getting a cam from tick and if i get the feeling maybe throw a 150 shot at the car down the road but thats a big maybe. my question is it worth it to go from the 90 to a 92 since ill be doing a cam
Old Feb 17, 2013 | 07:43 AM
dr_whigham's Avatar
The Scammer Hammer
Veteran: Marine Corps
Depends on what the HP/$ gain will be to you.
Personally, I would, if you can get a decent amount for your combo and only come out of pocket a little bit for a 92/92.
Old Feb 17, 2013 | 07:48 AM
HioSSilver's Avatar
No....it's not worth it to go to a 102 either.....been there done that.
Old Feb 17, 2013 | 07:57 AM
SKULL's Avatar
yea i dont wanna shell out another 300 to go to a 92 for 5hp or another 1000 to change to a 102 setup if at most ill see 10 hp
Old Feb 17, 2013 | 08:13 AM
Blackpanther99's Avatar
You will see minumum gains for the extra bucks spent on the swap. Not worth it in my opinion.
Old Feb 17, 2013 | 08:18 AM
DaFireMan's Avatar
is your fast ported?
Old Feb 17, 2013 | 08:25 AM
HioSSilver's Avatar
What's the mods on your vette?
Old Feb 17, 2013 | 08:37 AM
You should at least port your 90mm if it isnt already.
Old Feb 17, 2013 | 09:11 AM
redtan's Avatar
I thought the only difference between the 90 and 92 was the slightly bigger opening (by 2 mm) and the fact the internals are openable the same as the 102. If that's the case, then you prolly won't see any performance gain at all, 2mm bigger opening is meaningless...and nothing that you can't open up yourself on the 90.
Old Feb 17, 2013 | 09:27 AM
R6cowboy's Avatar
This is what I thought as well. The Fast90 and 92 intakes are exactly the same except for a 90mm and 92mm TB openings. There would be no gain what-so-ever if this is true because a 2mm TB opening won't make the slightest bit of difference in this case. OP if your Fast90 isn't ported, getting it and the TB ported by a reputable shop would do much more justice rather than swapping it for a Fast92.
Old Feb 17, 2013 | 01:17 PM
batboy's Avatar
Don't waste your time, as been said, nothing to gain between a FAST 90 and a FAST 92 except a thinner wallet. If you want some more power, have your FAST 90 ported, it should be good for about 10 hp or so.
Old Feb 17, 2013 | 08:04 PM
SKULL's Avatar
i did a dyi port on my 90 but i heard before the 92 was just a better design so was curious on if it was worth it or not. but i can see it is not
my car is just full bolt ons but looking to do a cam in the next few weeks
Old Feb 17, 2013 | 08:09 PM
badazz81z28's Avatar
Yea, Its the same intake with the exception of the throttle body opening.
The increase in power would not be worth the cost of a 92 or 102....that is unless you are looking for every last pony.
Old Feb 17, 2013 | 09:11 PM
SKULL's Avatar
no not at all lol penny per hp isnt worth it to me. next is cam and if it isnt enough ill sell the car and get something else before i get to deep into the car again
Old Feb 17, 2013 | 09:43 PM
batboy's Avatar
It's the FAST 102 that is a slightly different design.
Old Feb 17, 2013 | 10:48 PM
TT427's Avatar
I thought the new 92 models were redesigned a little?
Old Feb 17, 2013 | 11:04 PM
99Bluz28's Avatar
Stick with the FAST90, and have the heads ported by AI .
Old Feb 18, 2013 | 04:49 PM
Cra-Z Larry's Avatar
Is your car going to Tick on Friday??
Old Feb 18, 2013 | 04:50 PM
SKULL's Avatar
nah im gunna order a cam from them install myself with a friend and take to frost to get tuned
Old Feb 18, 2013 | 07:04 PM
Z28SteveA4's Avatar
yeah exactly what was said stick with the 90 and get that bitch ported. If you want you could open the 90 to a 92mm tb when it gets ported.
