V.2 Polluter on a 111LSA Idle!
Old Mar 14, 2013 | 06:59 PM
  #61
TheOneHodgepodge's Avatar
Martin what heads would you recommend to go with this cam? I've always been told to pick most of the parts after you select a cam. I've been staring at all different ones. RHS, TEA, AI, PRC.
Old Mar 15, 2013 | 10:06 AM
  #62
Sales@Tick's Avatar
I personally like Advanced Induction and Total Engine Airflow for my picks. I've had great results with their port work and they always consistently make the same gains each and every time.
Keep in mind, if you want anything higher than stock compression you will have to fly-cut with either V.2 Polluter cam, especially the 111LSA as the exhaust clearance is tighter with it being on a 111. What you can do though is either run a 243/799 casting which has identical valve drop to it's 241 brethren so you end up with the same p to v with stock valves, but you get a 64.7cc chamber instead of the factory 241 67cc chamber. What you can also do is go aftermarket casting with a 13* valve angle with a 65cc TFS casting and have the added benefit of a larger intake valve and exhaust valve along with the added compression a 65cc chamber gives you, while still keeping stock or slightly better than stock P to V.
Also AFR has a 64cc chamber in their 215cc head and since the head is cast that way from AFR you retain stock or very near stock P to V while gaining compression.
I believe PRC also offers a 62cc chamber with their As Cast 225cc heads along with their 227cc heads(the 227's may be a 64cc chamber). Since they have a 13* valve angle and are cast with that chamber volume instead of being milled, you end up with the same P to V or slightly better P to V than stock and more compression.
So there are several ways to gain compression with a big cam while keeping stock P to V clearance. If it were mine I would still fly-cut and mill to the maximum amount of compression I could run with the pump gas that is available to me in my area. Whether it be 91 or 93, the most compression you can safely get will always give you the best drivability, the best throttle response, the best power production and the best track times you can get.
I like to keep the dynamic compression ratio at 8.5:1-8.6:1 and under if 91 octane is all that's available, and 8.9:1-9.0:1 if 93 octane is available.
Old Mar 15, 2013 | 05:59 PM
  #63
Awesome info thanks. I was staring at those PRC as cast 225 and RHS 225. They were kinda what i was thinking. Being not far down the road they will get mounted on a LQ4 thought they would compliment that set up as well. Right now they will be going on stock LS1 M6. How well does it like N2O? My goal is 600 rwhp on the spray and at least 450 rwhp N/A.
Old Mar 16, 2013 | 01:44 PM
  #64
Sales@Tick's Avatar
Both Polluter cams the 111LSA and 112LSA love nitrous up to 200-250hp. I don't think you'll have any issue hitting your goals and even exceeding them easily.
Old Mar 16, 2013 | 06:35 PM
  #65
That is great news. Now to get in gear and spend the cash. Look forward to doing business with you and your guys at Tick. Your help is greatly appreciated.
Old Mar 18, 2013 | 06:55 PM
  #66
F8LWS6's Avatar
Originally Posted by Martin@Tick
Not a problem at all! First customer I've ever sold two Polluter cams to at one time LOL!
The wife should really love the new added power! With the stall speed we talked about for her car, that thing is going to be a beast!
Nothing like being first huh? We are both very excited to get these things, Should be some incredible power.
And I told her exactly what you said about that and she doesn't believe me! I think she thinks we are trying to kill her LOL. I'm sending her over to this thread so you can tell her we aren't playing around here!
Old Mar 18, 2013 | 09:58 PM
  #67
matt99's Avatar
pm sent
Old Mar 19, 2013 | 10:05 AM
  #68
LS1 Melly's Avatar
Thanks babe!
I've been bracket racing a pretty much stock car for 5 years now... this is going to be interesting!
Old Mar 19, 2013 | 02:16 PM
  #69
Sales@Tick's Avatar
LOL Why does she think that we're trying to kill her?
Originally Posted by LS1 Melly
Thanks babe!
We're trying to kill you and collect your life insurance don't let him lie to you....I'm in on it as well.
Old Mar 19, 2013 | 03:47 PM
  #70
LS1 Melly's Avatar
He's trying to kill me off because he wants my GTO! He's been eyeing the LS2 for his Corvette for a long time now!
Old Mar 19, 2013 | 10:33 PM
  #71
superman2002's Avatar
Well lost a lifter which may have killed my current cam. If it has ill be calling you guys. Pulling it this weekend. It will go well with my tfs heads.
Old Mar 20, 2013 | 04:57 PM
  #72
Sales@Tick's Avatar
LOL!!!
Sounds good! I love the sound of TFS head and a V.2 Polluter cam!!!
Old Mar 25, 2013 | 07:07 PM
  #73
Knight-Z06's Avatar
Originally Posted by Mike94ZLT1
https://www.youtube.com/watch?v=79chtl26aIY
THAT is how I want my car to sound!
that **** sounds untuned , or like **** , take your pick
Old Apr 8, 2013 | 01:32 PM
  #74
Sales@Tick's Avatar
Just to inform you guys that are following this thread, this car just went 125mph in the 1/4!
