stall speed for GMPP LS STAGE 2 CAMSHAFT
Can anybody tell me a stall that would work well with the gmpp ls stage 2 cam? I dont want anything about custom cams or different cams please the specs are truck will be street/strip use with dyno tune/intake and exhaust 227/ 239 .551/.551 108 LSA
After searxhing for a few hours. About converters and the cam..I found that the cams torque curve starts around 2800 in an ls7 and ends at around 4800 I didn't really want to have a high stall in the truck and I wasbn sure if the 3.73 posi made a difference till now. So would a 2600-3200 stall from circle d be okay? Also if I advance the cam a few degrees woul I be able to use a lower speed
