pull motor out top or bottom
Old Mar 4, 2013 | 07:13 PM
dkiller2135's Avatar
Default pull motor out top or bottom
I pulled the ls1 out the top and have issues with the ls2 and need to pull it. im thinking out the bottom this time. is there a way to pull the oil pan with the engine in the car.
Old Mar 4, 2013 | 07:22 PM
trans_am7935's Avatar
if you drop the K-Member about 2-3" and or jack the motor up then yes, otherwise no (not that i am aware of at least)
Old Mar 4, 2013 | 07:33 PM
evilz99's Avatar
Soooooooooooo easy to drop the motor and k member out the bottom. Its intimidating at first but its so easy I can do it with my eyes closed now lol. If you look their is a great write up by a girl with a white trans am. If you have any questions pm me.
Old Mar 4, 2013 | 08:22 PM
I pulled it out with the hood and balancer on. but can I drop it out below with a lift. if I lift the frontend with a cherry picker how will i roll out. give me a heads up and steps first to last. struts.,brake lines. steering linkag. fuel line. transmount. ...
Old Mar 4, 2013 | 08:57 PM
97camaro383's Avatar
I just pulled my motor and tranny a couple nights ago. I left motor on the k member and lowered tranny onto a creeper. I didn't use my cherry picker at all, I just lowered the k with a jack and then pulled the whole thing out.
Old Mar 5, 2013 | 07:08 AM
mjs1012's Avatar
Out the bottom no doubt. I did it in my driveway last year for the first time and got it out in a weekend taking my time.
Old Mar 5, 2013 | 05:05 PM
chrisfrost's Avatar
If You pull it out the top , You can have the engine/tranny out and the engine on a stand from start to finish in from anywhere 4 hours to 8hours depending on You're experience .
Old Mar 5, 2013 | 05:13 PM
VTC_WS6's Avatar
Yup.. Never did it from the bottom though if I had a lift that's the obvious route to take. I did pull from the top twice, pretty straightforward with the hood off the car.
Old Mar 5, 2013 | 05:31 PM
batboy's Avatar
The manly way to do it is on top.
Old Mar 5, 2013 | 09:20 PM
SWEET98SS's Avatar
I have a lift and did it out the bottom. Its great to have it all out and wire it up, put the headers on, tranny, almost everything then drop the car on top. It makes it so everything is right in front of you while install everything.
Old Mar 5, 2013 | 09:36 PM
yonerhottlt1's Avatar
Bottom, no questions asked.
Old Mar 6, 2013 | 08:40 AM
Snkebait95's Avatar
Bottom, just like sweet98ss said, very awesome to assemble everything outside the car and just drop the car over it and go. I put the front tires under the rear tires for stabilty, and use a engine hoist to lift the car high enough to put on the real tall jacks from harbor freight, put a metal table with wheels from harbor freight under the kmember and trans then unbolt the kmember and roll it out sideways.
Old Mar 6, 2013 | 08:54 AM
2000PewterT/A's Avatar
I would go through the bottom, it is way easier in my opinion.
Old Mar 7, 2013 | 02:55 PM
whats supporting the front of the car If you have no lift
must you pull the heads and intake aswell?
Old Mar 7, 2013 | 03:43 PM
lemons12's Avatar
I have pulled all mine from the top. I like being able to move the car.
Old Mar 7, 2013 | 03:51 PM
I have two big jack stands (you can see them in the top of the second pic) on the frame behind the front tires holding the car up. You don't have to pull the intake/heads to remove the motor, I did when I was trying to find out what messed up in the motor when I had a valve break.
Once I get the motor & tranny seperated and off the k member, I normally roll the empty k-member back under the car and install the 6 bolts and struts so I can roll the car around if I need to.
Old Mar 7, 2013 | 03:56 PM
ska4life07's Avatar
Going from the bottom is soooo easy!
Old Mar 8, 2013 | 12:54 PM
blackblurr_00gt's Avatar
Why does everyone unbolt the struts from the top i always undo the bottom bolts and leave the struts on the body.
Old Mar 8, 2013 | 01:25 PM
EastTn6.0's Avatar
Bottom is pretty easy.
Old Mar 8, 2013 | 06:04 PM
FAD2BLK93's Avatar
If u want to just get to the oil pan u could use the engine hoist to hold the motor in place and unbolt the six frame bolts and just drop the k member. Then u could remove the oil pan no problem, right? Or am i missing something here? But to pull the motor i have done both top and botom... I prefer topside!!!!
