100k + 99 LS1 Engine, 6800 Rev limiter is Stock Rod Bolts Safe
Old 03-15-2013, 07:19 AM
ckpitt55's Avatar
Originally Posted by zachary3
i agree
and yes its about the same price so i rather get arps it makes since to me
and was those tolerences from new unsed parts ?
intresting data
brandy new parts. still in spec, shows you that everything has tolerances....it does not mean a lick when someone says something is "good". if you care about the longevity of an engine, messing with key components like this requires some vigilance in making sure everything is right. surely not the fastest or easiest way to go about it, but a little time and $$ up front will save you much more of both of those things later on down the road.
Old 03-15-2013, 10:11 AM
boostit5.3's Avatar
i've been turning my 99 5.3 (stock long block) to 6300 on shifts and 6750 rev limit, also spraying an occasional 200 shot on top lol. its been about 6 months now no problems (knocks on wood)... but my cam also pulls to 6500 so i may be adjusting my tune and put the limiter at 6850 and shifts at 6400-6500. not sure where i read it (i went search crazy) but i thought i read somewhere that if its 99+ as long as your not spinning over 7k daily they will hold up, and a couple people where taking them to 7300 quite often with no problems. but as said every setup is different so its up to you, i took the junkyard route if this motor chucks a rod ill buy another motor for 300-400 bux and part mine out for prolly 300-400 bux lol...
Old 03-15-2013, 10:17 AM
boostit5.3's Avatar
o yeah also motor has around 130k, only upgrades from stock long block is valve springs, cam, and pushrods.
Old 03-15-2013, 10:26 AM
mchicia1's Avatar
Leave it at 6500 rpm. What are you gaining from those extra 300 rpm anyway? Think about it.
The stresses on the rod bolts are exponential as rpm increases, not linear, so even 100 rpm can make a huge difference.
Old 03-15-2013, 11:01 AM
boostit5.3's Avatar
my reasoning is because im running out of gear in the 1/4 but not by much.
Old 03-15-2013, 01:03 PM
zachary3's Avatar
Originally Posted by 01ssreda4
Should be fine. Trans will probably go first under those conditions.
Im building my trans mildly stalled, modified shift kit, trans cooler. upgraded 3/4, beast sunshell, of course amsoil atf lol and and other upgrades i cant remember of the top of my head trans only has 5k miles
Originally Posted by Busted Knuckles
Rod bolts are the single most stressed fastener in your entire engine.
Why take a chance on losing ALL of it???
I agree 100%
Do it right now or do it right with a different block lol
i believe its 99+ block casting change also during that time hence why 98 isnt a sought after performance block
every setup is different and i dont know the entire history of the block i have
during tear down there was a bent pushrod hence upper engine ticking so i know who ever had it before me was revving it high so it s not worth the risk
if i knew the block history better and know block was taking care of then my decsion would of been to just run with stock rods till a complete rebuild
Old 03-15-2013, 02:39 PM
adamantium's Avatar
Been reving my stock short block and cam with 101k to 6200 almost daily.
Old 03-15-2013, 03:37 PM
Tainted's Avatar
98 blocks (ls1) have thinner sleeves therefore cant be bored over only a slight hone.
Old 03-15-2013, 04:18 PM
zachary3's Avatar
I agree only a slight hone once block is trash no hope
Quick Reply: 100k + 99 LS1 Engine, 6800 Rev limiter is Stock Rod Bolts Safe
