looking for suggestions
Car is a M6 with suspension mods and will have a 8.8 rear with 4.10's.
Car is not a DD, will hopefully see track use.
What I have so far:
LQ4 short block
Set of 8 LS2 pistons
243 heads with Trunion upgrade for the rockers
LS6 Intake till I can afford a FAST
All my LS1 accessories & oil pan
LS2 Timing Chain
Plan on getting:
LS6 oil pump
Chrome Moly Push Rods
Open for suggestions on CAM....want mid 400's would love higher is possible without N2O.
Going with this setup till I can save up for a 408 build later (much later).
Here is a Tick shelf grind that'd be cool:
http://www.tickperformance.com/tick-...r-ls2-engines/
Since you're going with essentially an Iron Block LS2, try the SNS Torquemax series for LS2 engines from Tick. The Stage 3 is more of a track cam, so that should work nicely. And you have the choice of more aggressive or milder lobes based on how much you want to beat on the springs/lifters/pushrods/rockers/valve tips.
All are the same price from Tick.
We've made 440rwhp/405rwtq with a LS2 intake, 243 heads, 1x7/8" LT's, ORX, Corsa Cat-back and a vararam intake. Still had stock TB, stock MAF and no other bolt ons.
With a Fast I'd expect this set-up to easily clear 450rwhp/415rwtq if not more!
