How critical is precision while flycutting?
What I am doing is setting the collar 0.090 above the guide (with no seals) with feeler guages and then cutting until 0.010 no longer fits between the collar and the guide. I find it is a waste of time to try to "spark it out" when cutting. You can't use a depth mike to measure the depth since the notch is not flat. You can't use most verniers because the probe has a square end. I have been laying 0.080 worth of feeler guages in the notch and trying to sense the match between them and the deck of the piston with a finger nail. So far it takes two or three tries to get close, but I can only guess at what "close" is. I think you can feel a couple thou difference with a nail, but don't really know.
I think you can use geometry to figure the volume of the slice, but I haven't tried yet. I don't think that +/- 0.005 will hurt balance or compression, but can't prove it yet.
BTW, PP LQ9 heads going on ...
I have felt that thought trying to sneak into my head but having spent the money for the cutters, I quick force it out
Good luck!
Dale
