bump stick
Old Mar 24, 2013 | 10:24 PM
adamk4566's Avatar
Default bump stick
bought a speed inc si6 cam 235/240 .621 .609 btr dual springs 7.4 pushrods ls2 timing chain to go with my pi 3600 vigilante converter and ls6 intake im getting excited to get this done
Old Mar 25, 2013 | 07:04 AM
mark21742's Avatar
Make sure you check piston to valve clearance. Should be a fun ride when done
Old Mar 25, 2013 | 08:53 PM
adamk4566's Avatar
of course i will check ptv clearance hoping i will not have to fly cut as speed inc told me it will not be necessary with stock heads which is the only reason i went this big
Old Mar 26, 2013 | 01:14 PM
mark21742's Avatar
I had a hair milled off mine at the time and ran a 238/242 when I pulled the motor down to go bigger there were marks on the pistons where the valves just touched a few times...I got lucky and didnt do any damage
Old Mar 30, 2013 | 12:57 PM
i420tom's Avatar
Mark what was the full specs of your cam?
Old Mar 30, 2013 | 01:03 PM
poltergeist 02's Avatar
With that cam I would run a 4K stall to maximize performance.
Old Mar 30, 2013 | 02:23 PM
i420tom's Avatar
I would run a 4k+ stall as well, and I do, with a smaller cam. but Adam has his mind set on a pi3600, it probably stalls a lil bit higher than say a ss3600 so he will be fine. little bit More wife friendly and more street friendly with the 3600
Old Mar 30, 2013 | 04:44 PM
mark21742's Avatar
I think I'd run a 4,000 stall with it too.
Mine was a 238/242 .595/.595 112 lsa. Now I jumped up to 255/277 .624/.624 115 lsa that pulls hard as hell all the way to my 8,000 rpm fuel cut.
Old Apr 10, 2013 | 09:20 PM
adamk4566's Avatar
installed my pi 3600 vigilante and its loose as hell and flashes about 4000 rpms at wot so all should be good under the hood
