Just Discovered New 243 Heads!!
Well first of all does it have a LS6 cam ? While it is possible , its not likely you have LS6 stuff. There are other ways to tell if you do have LS6 valves, the LS6 had a smaller base circle so the LS6 valve was .0236 taller . So to do this install correctly on a LS1 or aftermarket cam they should have installed push rods 7.375 length. Just pull a push rod and check it . If they didn't change the length, over time it will be a bit noisy.
