What causes 1 fouled plug?
Here's the situation. I installed H/C.. I went to the track and sorta mis-shifted 1-2-3- 2... I caught it pretty quickly though. Got a blinking SES...
Pulled the plugs and only the #5 plug was bad. I changed the plugs. The SES light seems to only blink very seldomly and only at idle for 5 flashes and then it's just steady like it normally is.
I told the guy that was gonna tune my car about the #5 fouled plug, and he said that I may have damaged the valve seal or something on that cylinder.
Anyone else have a similar problem to this. Could a bent rod cause this also?
Thanks..
I went down.. Pulled all of my pushrods to see if I bent any. None were bent (shrewwwww) thank goodness.
However, I changed my plugs on Sunday.. It is now Wed. and the same #5 plug is completely covered with some kind of soot. Not oil or gas, kinda like a thick black powder. I only start the car to let it idle and I took a 20 min drive on Mon.
I'm totally lost. Also the SES light only blinks at idle.
Could it be that my car just needs a tune. I've installed LT's, removed the cats, and done a h/c swap. I'm hoping that this is all that it is, but it just seems weird that it's only fouling one plug.
I also tried the feeling the header from that cylinder on startup to see if it was firing, and yes. It got hot quick as hell..
Any more ideas?
Just a quick question? Can you bend valves and not bend a pushrod?
Still tryin to get this question answered. Can you bend a valve on a bad shift and not bend a pushrod.
Also how accurate is the rolling the pushrod on glass to verify whether or not it's bent?
Thanks
So this is what I need to do this afternoon.
1)Run Compression Check on #5 Cylinder
2)Check PCV Valve
3)Move #5 injector to #3 Injector
What do you think the chances are that I have a shot ring or damage piston on that cylinder? If that's the case, how hard is it to pull a piston?
2)Check PCV Valve
Compression test will tell you if there is a problem with rings or valve. Switching injectors will tell you if it's the injector. If neither of those 2 tests shed any light I'd settle on the valve seal.
To answer your question you can bend a valve without bending a push rod. In fact, I don't think you can bend a pushrod without bending a valve IF THE PISTON CONTACTED THE VALVE. Most of the time you bend a pushrod it's from simple valve float. The pushrod comes off the lifter or the lifter comes off the cam and when they meet up again, the lifter is coming up while the rod is coming down and you bend your pushrod...this is NOT due to valve hitting the piston or you WOULD see a bent valve also.
Good luck figuring out your problem.
