Help me decide between Speed Inc SI5 and Tick SNS2 Cam.
I am probaly going to cam my car after this summer when my budget is more friendly. My car is a 2000 Trans Am A4. Speed INC is putting a Yank SS3600 stall in next week. My car is a summer nice day only car, and goes to the dragstrip once or twice. It will be running the stock 853's for the forseeable future.
Specs:
Speed Inc SI5: 231/237 .589/.595 112LSA
Tick Performance SNS2: 227/235 .61x/.62x 110+3 LSA
The information on the Tick website for this cam makes is sound perfect for what I want, 1800-6400 RPM powerband, a lopey idle but not too big as to loose power under the curve. I assume the SI5 will give similiar performance as the specs are very close, but I only want to do this once, and I am not sure if the extra lift of SNS2 would make a large enough power difference. I know that 400RWHP is not likely with the stock heads, but I would like to get as close as possible. The car will have all required upgrades that go along with either cam and full tuning.
What are your guys thoughts? Or are these cams too large and I should consider may a 228 cam?
Thanks.
Specs:
Thanks.
I recently purchased a SNS 3 from Martin and will be installing in the near future. Call Martin and he'll give you the full scoop on the SNS cams. These cams also come in a milder version if your worried about Lift and valvespring life. GL !
S15 here I am happy with it. Speed Inc always takes care of me. I made 372/372 that's with out ported tb, pulley, and a terrible y pipe. I am hoping for closer to 400 with the ported tb, pulley and true duals
I can only speak for the Tick Performance SNS Torque Max Stage 2 cam because that is what I have. It's one hell of an "all around" cam. Not too big, but by no means too small. Great torque throughout the RPM band and the son of a bitch will carry power all the past 6500 RPM's.
I have the sns 3...I'd go with martin just for the fact that he is the only sponser on this site who constantly interacts with us/members. Giving advice, results, vids on all of his cams. His customer support is superb to say the least. Theirs a couple of his threads just below.
You should definitely give Martin a call and he can set you up with what you want. Street Heat stage 2 would be a good cam if you want someting closer to the SI5 cam.
im currently installing a si6 cam from speed the tick sns cams are bad *** to say the least and martinis one kick *** dude my buddy put a si5 in his camaro about 5 years ago its an auto car with a yank 3600 ss long tubes ory magna flow exhaust ls6 intake he made 396 rwhp and i think about 380 rwtq plus it sounds nasty too
tick has some great guys . i had Jonathan bench tune my pcm . he accidently forgot about abuse mode. but we didnt know at the time. i called him he said no problem bring car up there and he would find the problem he said he needed the car to find problem.i told him i can't i dont have anything to tow with. i live 1.5 hrs away. so we talked a little longer about what the problem could be . he came down to my house and found it was abuse mode . not to many shops are going to that.
Wow, thanks for all the kind words in this thread! OP if you have any questions on any of our camshafts, shoot me an email to martin@tick-performance.com as my PM's get pretty full and take me a while to respond to.
