How much difference in degreeing cam in car vs. on engine stand
Obviously I'm going to use light weight checker springs but I'm not pulling the heads off to use a solid lifter. Will the light weight spring be enough to compress the lifter?
I have a big Comp degree wheel and a small Mr Gasket wheel. I'm sure I've going to have to take my accessories off but which one have you used?
Thanks for any info on this.
J
It's been a while since I've degreed a cam and hadn't gotten that far in my head yet. They sell a tool that threads in the spark plug hole don't they? Trending Topics
Bad news is the checker springs are too much for my lifters.
So I wasted most of the afternoon. There is no way in hell I'm pulling a head off so dot to dot it is!I had forgot the pump has to come off to put the comp crank socket on. I am not looking forward to having to put that back on. Since I did not have the fore thought of having to take the pump off that means I do not have a new O ring to put on.
Does a parts store sell just the o ring? My guess is no and I will have to get one from the General Monday.
Such is life. Maybe this will prevent someone else wasting an afternoon like I did.
