Patriots heads
Old Apr 13, 2013 | 10:59 PM
Nvrfastenough87's Avatar
Default Patriots heads
Hi guys, I'm new to the forum. I got a 99 C5 a few months ago, Just got done putting on bbk shortys and obx exhaust. It sounds like a beast, and runs so much better than stock.
Now ofcourse I have the mod bug or whatever its called so I'm looking at cams because with an LS1 you might as well spend the $$ and get it over with. I don't want to spend as much for a fast manifold and tb when I could have a tsp 228r.
I should be getting a refund check for the warranty I never used on my last car in a few weeks and I was going to use it to get the tsp cam, hd oil pump, timing chain ect but I came upon this and thought it might be a better idea.
I most likely wont have this amount of money any time soon again so it seems like a good idea to get this and then start collecting the pieces for the cam install one by one even if it takes a year.
What do you guys think? - http://www.aacorvette.com/performanc...roducts_id=191
Since it claims the compression raises I take it I'd have to get a tune right? Would it be ok to run this with a stock cam for up to a year? I'm sure Ill be able to do it alot sooner than that though.
Thanks everyone
Old Apr 14, 2013 | 12:14 AM
mkvamso's Avatar
Patriot heads were pretty good for the price. On par with tsp or tea factory castings. Id change the cam if I was going the the trouble of swapping heads, you'll get a lot more out of those heads with a new cam. Just start collecting parts as you can and do it all at once.
Old Apr 14, 2013 | 12:39 AM
Droptopws6's Avatar
I ran Patriots on my '97 corvette and went from 12.30 to 11.70 5.3 Patriot heads were the only change. I had a Yank 3200 stall, 3:42 gears, long tubes, and LS6 intake.
Cam was a comp 228 can't remember all of the specs
Old Apr 14, 2013 | 08:05 AM
JustAFooL's Avatar
Don't waste time doing heads without cam. There is gains, but they shine best when put together.
Yes, the car will have to be tuned IMMEDIATELY after you finish any major modifications or some serious damage can occur. If I were you, I would either in with a bigger cam, or mill your heads. I'm running a 224/230 comp with around .580 lift and milled my Patriot stage II 243 to 59cc. Helped compression out a ton. Clearance was tight, but no question its a better performer.
Old Apr 14, 2013 | 08:50 AM
onefast84's Avatar
I just installed a set of patriot stage 3 heads on my 6l and there is a very noticable "seat of the pants" difference. Hoping to go to the track soon for some ets. Have you called these guys? Patriot is no longer, they are now called promaxx. So I would call them to make sure they have them before planning a build around them. Also I would get the heads, and get a custom cam to match your setup.
Old Apr 14, 2013 | 12:32 PM
Oh I definitely plan on getting a cam too, just figured I get the more expensive part out of the way.
Should I go for the 10.5-1 or 11-1? would there be a big difference or would the 10.5 just be safer.. isnt that stock zo6 compression?
Also, the ad doesn't mention rockers pushrods or lifters.. do I have to buy all that or swap it over from the stock heads?
Old Apr 14, 2013 | 12:38 PM
alexus6798's Avatar
11-1 would gain you more performance and better throttle response and still be pump gas friendly. Also, those shorty headers aren't going to gain anywhere near what a set of longtubes would net you.
Old Apr 14, 2013 | 01:59 PM
Ok I'll definitely take your advice on that.. I thought about the LT's but theyre just so expensive I figured gettin shortys and having an exhaust shop cut out the cats and put straight (or some kind of resonated) pipes would be alot cheaper and give me great flow.. I live in FL so I can do that np.
Nice car btw
Old Apr 14, 2013 | 03:00 PM
alexus6798's Avatar
Nice car btw
Thanks for comment. If you decide to go heads and cam you definitely want long tubes. Yeah, having a vette, I don't think there is really a cheap choice for those. My car felt like a new car when I installed longtubes even though I did a Fast 90/90 and 85mm MAF at the same time but you can definitely tell the difference. The exhaust note is awesome.
Old Apr 14, 2013 | 03:09 PM
low2001gmc's Avatar
MASS seller approved
x2. better to collect parts as you can and install all at once. long tubes will definitely be a must for optimum performance.
Old Apr 14, 2013 | 05:53 PM
Well I know people bash OBX but they have LT's and xpipe for about 675 or something on ebay. I got the exhaust and not only does it look Fn great but it sounds great too. The tips are so sick and the mufflers are really tiny so you lose ALOT of weight but you don't get the crazy sound. I'm really impressed actually. So I would think their LTs would be the same.. I hear they just copy the most expensive brand and just have it made in china for a fraction of the price.
But I'm just gonna do the heads first to get it outta the way. The cam will just take me putting away 50 bucks every paycheck for a little while and then I'll have the real deal instead of just a cam. It'll be a year before I have this much money at one time again (tax time).. and it wont even be that much because I'm in trades. So its now or never.
Old Apr 14, 2013 | 06:08 PM
2000PewterT/A's Avatar
Do the heads/cam and whatever other mods all at one time and get it tuned ONE time. No reason to do something and have to redo it later. It will save you money in the long run.
Old Apr 14, 2013 | 06:44 PM
True. Youre right about that.. a tune isnt cheap. Wish I had the time to learn how to do that.
Old Apr 14, 2013 | 07:23 PM
mkvamso's Avatar
IMO, obx headers are great, there's not much difference between corvette headers and f-body headers except the price. I'm not sure why vette parts are still so expensive but you get out of that "corvette tax" with obx headers, they look and fit good. I'd reccomend them for someone trying to save some money.
If I were you I would start with boltons, a cam, and a tune. Little things will eat up a build budget real fast. You can add heads in the future and see even more gain, but dollar per HP isn't really there unless you've done other mods first. With full boltons and a cam you'll probably see an 80hp increase over stock with a decent setup.
Old Apr 14, 2013 | 08:45 PM
Just found some LTs from texas speed.. no cats so it would be crazy loud but theyre even less than OBX and they come with all the extra bs you need too.. new dipstick o2 extensions.. hmmmmmmm
Old Apr 15, 2013 | 04:46 PM
Found these.. seems to good to be true compared to other pricing.. If these check out I can get the cam at the same time.
http://www.ebay.com/itm/LS1-LS2-LS6-5-3-5-7-FULLY-CNC-RACE-HIGH-PERFORMANCE-ALUMINUM-CYLINDER-HEADS-/180992905964?pt=Motors_Car_Truck_Parts_Accessories&hash=item2a240492ec&vxp=mtr
Old Apr 15, 2013 | 09:38 PM
transwiz's Avatar
I would not buy these heads.If it looks to good to be true,it is. I would not take a chance of them falling apart at say 5k miles.
Old Apr 16, 2013 | 12:22 AM
Slo_240sx's Avatar
I would be very weary about those heads. As everyone else is saying I would wait, save up and do H/C all at once. Its not fun to tear an engine apart and know you'll have to do it again. You'll spend money on fluids twice and alot more time than rather doing it all at once. I have a set of thick deck Patriot Predator heads for a steal if you're interested. Pm me if you are. Goodluck!
Old Apr 16, 2013 | 03:16 AM
Yeah I was thinking the same thing... Im not going to get them just to be safe but man I hope you guys are wrong... the guys sold 39 of those head packages..thats alot of people getting screwed
Old Apr 16, 2013 | 06:55 AM
TheWolfMatt's Avatar
If it were me, I'd go with those patriot heads, they're proven, and we know they work. Those ebay heads you have posted are already on another thread in here and should be worth a look if your interseted in a gut busting laugh as there is a really funny argument going on in there. Those are ProComp heads (Chinese Crap).
https://ls1tech.com/forums/generatio...bay-heads.html
But yeah, stick with the patriot heads you had picked out or talk to one of the TSP guys about any recomendations for your build.
