alignment tool
Old Apr 14, 2013 | 07:04 PM
tom70's Avatar
Default alignment tool
getting ready to put oil pump and front cover on. dumb question but is there an alignment toolto align front cover and oil pump?
thanks
Old Apr 14, 2013 | 08:14 PM
Gray86hatch's Avatar
The pump yes. Car Shop Inc sells one for the pump
Covers can be done with a straight edge or the Kent Moore Tool but it is expensive.
Tim
Old Apr 14, 2013 | 09:34 PM
sjsingle1's Avatar
ebay is your friend for GM tools....ask me how i know
Old Apr 15, 2013 | 07:13 AM
pauls99z28's Avatar
is this alignment tool neccesary for cam install?? Last cam swap i did in 05' i dont think i did anything special for the cover and oil pump install..
Old Apr 15, 2013 | 11:19 AM
vettenuts's Avatar
I used a six inch metal rule graduated to 1/64" to set the cover in place and center it on the crank shaft. That is all the GM tool does anyhow. I don't like using the seal to do this because it will put a bias in the seal position.
Old Apr 15, 2013 | 02:11 PM
tom70's Avatar
Was going to cover loose till put balancer on thought that would center cover am I wrong
Old Apr 15, 2013 | 09:04 PM
Burken01's Avatar
I put the front cover on loosely then the balancer, center the cover over the balancer and make sure the bottom of the cover is flush with the bottom of the block before you add the oil pan...
