Oil pressure drop to 0 :0 help!
Old Apr 15, 2013 | 12:26 AM
1_MEANZ28's Avatar
Default Oil pressure drop to 0 :0 help!
So i changed the oil on my 98 camaro z28 ls1 .oil pressure increased.car has never had any problem.ita my dd. So today i took her to the track.ran the car at the finish line i noticed oil pressure droped a bit..but as i was parkin it i daw the oil pressure at 0! Sudden drop..rapidy turn it of and check oil.everything looked good..let her sit for a bit and turn her on to check if i hear any noises.no wierd noises.oil pressure whent up but not that much.drove her home and everythig was good.
Soo
Oil pressure droped to 0 then when i turned her on it came back up.
No weird noises.
Oil looked good.
No over heating
Car keept running good on the way home.
But oil pressure wasent as high at it was.
Any ideas ?
Thanks in advance.
I think the opsu when out..what do you guys think?
Old Apr 15, 2013 | 12:47 AM
sweet99ss's Avatar
Just went through similar situation... Changed opsu, than I checked with a mechanical gauge and was still having same issues. Put new pump in and still same problem... My engine always ran dead silent though so IDK!
Old Apr 15, 2013 | 12:51 AM
1_MEANZ28's Avatar
That sucks! I hope the sensor will fix the issue .or i might aswell start saving for new motor..
Old Apr 15, 2013 | 12:58 AM
sweet99ss's Avatar
Yea I just bought new motor... I'm ready to pull the bitch to see wtf is going on though...
Old Apr 15, 2013 | 01:28 AM
1_MEANZ28's Avatar
I turned car back on after letting it cool down.oil pressure came up fast was at 40 then reved it up no more than 3k and oil pressure increased to 60 65..im hopeing its just opsu sensor messing up..any thoughts? Everyone
Old Apr 15, 2013 | 01:32 AM
Black01Bird's Avatar
Sounds like its the sensor to me, being you hear no weird noises, and the oil pressure being fine.
Old Apr 15, 2013 | 01:57 AM
ckpitt55's Avatar
try the opsu first. if that doesn't fix it then you have bigger problems and I would stop driving the car until you get it resolved.
Old Apr 15, 2013 | 08:54 AM
1_MEANZ28's Avatar
Yea ima do that first.today oil pressure was sky high cold 60 65..as it was warming up it wouldint go lower than 40,im really hoping its the opsu.its my dd.so i have to drive it.has no problems.
Old Apr 15, 2013 | 11:59 AM
1_MEANZ28's Avatar
Bump..
Old Apr 15, 2013 | 07:59 PM
1_MEANZ28's Avatar
Any more inputs appriciated
Old Apr 15, 2013 | 08:07 PM
sweet99ss's Avatar
What else do you want to hear? Go change the opsu and you will have your answer... It takes 30 mins to change. Go to orielys and get the special socket that goes over the sensor and you can just get over to it and remove and reinstall it. Or just pull the intake. Witch takes a bit longer, but still very simple...
Old Apr 15, 2013 | 08:54 PM
1_MEANZ28's Avatar
Just if anyone else has faced something similar and fixed it.i will be doing that sinple swap.just wanted to hear anthing else..it appears its just the sensor thats Acting up.pressure today was 60 all day long..
Old Apr 15, 2013 | 08:59 PM
SMKE EM's Avatar
I had a very similar issue with my SRT4. The SRT Autometer OPSU was faulty and actually leaking oil showing me 4psi-0psi at warm idle sometimes.
I changed the OPSU and with no leaks have upwards of 100psi on cold starts and nothing lower than 20psi at idle.
You should really change the OPSU as suggested, or buy a mechanical OPG to test the car if you are in a hurry to drive it.
Old Apr 16, 2013 | 12:12 AM
LilJayV10's Avatar
keep driving it. You will find out soon enough if its the OPSU or not.
