Its Alive!! VIDEOS ADDED!! TEA stage 2 ls6 heads paired with the Tick SNS stage 3 cam
Thanks! I bet the 150shot will be fun on this setup! I should have motor back in the car this weekend after I check PTV clearance.
TEA/Mike is Awesome!! I really wanted AI heads at first but I like being able to call and have someone answer all my questions(too impatient to wait on emails LOL). Ill definitely send my next set of heads to TEA.
[QUOTE=LilJayV10;17338972]Senical,
I hope my car runs as good as yours, I doubt I will 60 ft as good as you though.QUOTE]
x2 I hope my car runs that good also!
I will definitely keep the thread updated with results and videos. How do you like the SNS3 so far?
No. 3(exhaust) & No. 4(intake) are the TEA stg2 ls6 heas with 2.02 intake valve.
I'd like to see a copy of your flow sheet if possible.
[QUOTE=97camaro383;17339108]Thanks! I bet the 150shot will be fun on this setup! I should have motor back in the car this weekend after I check PTV clearance.
Funny story, I tried to get AI at first too. Didnt work out. I'm glad it didnt.
Theres more in my 60'. The mph is good for 10s. Make sure and post results
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
I would look no further than Ai or TEA. You cannot go wrong with either, just remember with the aftermarket sized valves you will lose P to V clearance from the increase in diameter.
[/QUOTE]
Our setups are really similar,I just need to get a fast intake. Got any videos of your car running?
#34
You definitely should, I wouldve liked to see the 11.1 pass! Also is your yank 3600ss really tight? I have the same one and it seems extremely tight compared to my buddys circle D stall
#36
Those are solid numbers on those heads. You will have a strong car. I had ported 243's on my car before my turbo setup. It was a 347 cid, full weight car, M6, ran 10.90's @126.0 on a 1.6 60'. Ported stock casting are very capable. And not just the 243's. Too many guys get all geeked out about aftermarket stuff and miss the truth.
#37
#38
CHS stage 3 heads and forged bottom end. Compression was 11.0:1 I was running 25X/25X custom solid cam and shaft rockers. FAST 90 intake and TB and headers of course. It did this on pump gas/103 mix. If I could have launched this pig I believe 10.70's would have been easy. But I went turbo instead.
#40
Its interesting seeing the different flow sheets, thanks for posting!
UPDATE:
I got the motor and trans put back in over the weekend, but I still have a few other things to finish before I can start it. Hopefully next weekend I will post some videos of it running!
UPDATE:
