LS1 not making power
Old Apr 30, 2013 | 05:55 PM
peteggl's Avatar
it's not my one bad experience, my uncle is the local engine builder here and you should see the crap he has had to fix because the people there don't know how to install a cam or any other engine mods
Old Apr 30, 2013 | 05:58 PM
peteggl's Avatar
and by the way he was changing my fuel pump, you can explain to memos that = a new fan and electric switch that I have to turn on and off everytime I get in the car I'd like to hear it
Old Apr 30, 2013 | 10:18 PM
peteggl's Avatar
Checked the codes again throwing 2 more codes for knock sensors
Old May 1, 2013 | 11:35 AM
LS1T56FTW's Avatar
Knock sensors won't cause that big of an issue, there has to be something else.
Old May 2, 2013 | 12:13 PM
peteggl's Avatar
well I was going to get the knock sensors tuned out but my tuner thinks the o2 sensors may be plugged in backwards after the transmission was installed I guess I'll try that next
Old May 2, 2013 | 12:22 PM
SSellers's Avatar
Have whoever did the trans check your trans pressures. I got a freshly done 700R4 once that acted similar and it was the pump. Or they put a deep pan on it with a short pan filter.
Old May 2, 2013 | 03:15 PM
peteggl's Avatar
what would be signs of the transmission pressures being messed up? it shofts perfect
Old May 3, 2013 | 10:24 AM
peteggl's Avatar
went under to look at my o2 sensors and here is what I found, looks like it could possibly mess things up
https://i.imgur.com/aC8uWz9.jpg
Old May 3, 2013 | 11:04 AM
DACTARI's Avatar
Yikes.
Old May 3, 2013 | 12:09 PM
LIQUIDZ28's Avatar
how do I data log a knock?
if you have an android phone get the torque app for it like 5 bux, then all you need is a bluetooth obd2 adapter.
I use the kiwi brand adapter ill see if i can find the link.
http://www.jegs.com/i/PLX+Devices/68...TOOTH/10002/-1
there is cheaper alternatives, but i live by mine and this brand is tried and prooven to be reliable. I would hate to plug in a "knockoff" brand for 25 bux and fry my ECU. just my 2 cents.
Old May 3, 2013 | 12:11 PM
LIQUIDZ28's Avatar
HOLY WTF!
they must have forgotten to unplug it and tore it right out.
good thing is thats just normal wire so you can fix this.
Old May 3, 2013 | 01:22 PM
  #32
LS1T56FTW's Avatar
Is that for the rear O2 sensors, or the front?
Old May 3, 2013 | 01:27 PM
  #33
peteggl's Avatar
I'm pretty sure it's the front I don't think I have rear ones
Old May 3, 2013 | 01:42 PM
  #34
DACTARI's Avatar
No wonder you're car has been heating up. You will have been running insanely lean.
Old May 3, 2013 | 04:44 PM
  #35
LS1T56FTW's Avatar
Well, I would fix the wire, and actually plug the O2 sensors in. Might not be a bad idea to get some new ones either. I am very surprised that the car did not throw any codes for that.
Old May 3, 2013 | 04:49 PM
  #36
smws6ta's Avatar
I know that shop would be buying me a new wire harness.
Old May 3, 2013 | 05:02 PM
  #37
peteggl's Avatar
I've got the wire fixed back up but it doesn't really seem to have made any difference, I read somewhere the codes need to be cleared before it makes a difference is that true?
and it was the o2 sensor where the exhaust connect to the header is that front or rear? because I only see 1 on each side
Old May 3, 2013 | 11:54 PM
  #38
smws6ta's Avatar
yes, need to clear codes. Disconnect both cables off the battery for 30 mins.
You should have 2 O2 WH that are near the front of the Bell housing and 2 more that are along the transmission. If they are plug into the ones next to the tranny your PCM might be getting no/incorrect data.
Old May 4, 2013 | 10:42 PM
  #39
peteggl's Avatar
well I replaced the o2 sensor harness or whatever that thing is called and now my car runs like absolute crap, like it did before I installed y converter with my cam. it cuts off if I don't let it warm up before putting it in gear and when I do get it going it just has nothing at all
Old May 4, 2013 | 10:53 PM
  #40
Redbull87's Avatar
+1 vote for everyone to get the torque app and elm 327 obd2 bluetooth adapter.it helped me fix my random misfires.
now your car seems to have gone from bad to worse.did you clear the codes after fixing the o2 sensor harness,is the other side o2 sensor ok?
