Can I rev to 7k safely?
Dyno'd the car yesterday and it was still climbing when they shut it down each run at 6K. I'm very curious to see what the car will make if it revs up to 7K. With my current mods can I rev to that kind of rpm reliably? Or atleast 6500 for that matter. And if not what else needs to be done internally?
MS3 Cam
PRC .650 double valve springs
Titanium retainers
Hardened chromoly pushrods
MS3 Cam
Titanium retainers
MS3 Cam
Titanium retainers
MS3 Cam
Titanium retainers
Wierd that they only took it to 6k....they know there is a cam in there right? LOL. As said tell them to go at least to 6,500...I shift at 6,700.
Did you just have it on the dyno or did they tune it also? Is your limiter raised for the cam?
i have spun my engine to 7000 a few times at the track i usually only spin it 6800 have been doing it for the past 2 years and about 24k miles and i hit the rev limiter at least 3 times a week minimum and hav had no problems i am running a stock bottom end but im a lq4 not ls1 not that it makes a difference there
I usually shift at 6k, mostly because after 6k it sounds like a screaming banshee and that along with my "scared" mindset forces me to shut it down/shift lol.
