What's up with Comp Cams ?
Old Apr 23, 2013 | 05:25 PM
  #61
Grimes's Avatar
GoodLink I have no reason to doubt what is stated in that thread. Of course anyone would want to run the best oil possible, within price and availability constraints. I think the good question to ask now is does it make sense to go out of my way to buy vr1. Or should I just continue to use m1 because I have been successful with it?
Originally Posted by 87silverbullet
Read the link I posted earlier. There are brands out there with less ZDDP and work beautifully because of their sheering factor. Look at what oil made #1. It only had 806 ppm of zinc compared to the rest. Its capability to protect against metal to metal contact is why it made #1. As I said before Valvoline VR1 10w30 conventional or synthetic is the best in my eyes. I do agree with you though on regular oil change intervals and so forth but no matter 100 miles or 3000 miles, wouldn't you want the best in there?
Old Apr 23, 2013 | 05:37 PM
  #62
JakeFusion's Avatar
Super Hulk Smash
VR1 is easy to buy. Big auto parts store sell it. So does Amazon. $5 a qt.
Old Apr 23, 2013 | 05:53 PM
  #63
87silverbullet's Avatar
I wouldn't. I was a big mobil1 user in my Buick T-Type and still believe in it. In that link there was an SN rated mobil that did real well. I would just use that.
The Pennzoil that made #1 I use that in my wife's Yukon but not because it made #1, but because its the easiest to find at Walmart.
My camaro will get Vr1 though
Old Apr 23, 2013 | 06:04 PM
  #64
Damian's Avatar
LSX Mechanic
Originally Posted by pauls99z28
I would like to share a reply from Comp Cams to my questions about type of Material,Tolerances, and Concerns we normal folk have..lol.
Take note of the link at the end of the reply. hope this helps
Here goes...
"Hello Plustiano and thank you for signing up on CPG Nation!!!
Comp Cams uses various materials to make camshafts depending on what is best for that individual engine and application. We use a wide array of materials due to the fact that we cover a very wide variety of engines. Austempered cam cores are not used in LS applications nor have they ever been by our company. Our LS cams are made predominantly from 5160 or 8620 material. Either the 5160 or 8620 material is more than capable of handling any Hyd. Roller LS application. The difference in materials used has no effect on quality control what so ever and I am not sure what would lead you, or anyone else, to believe that it would. Also all of our cores are produced in the US and come from 1 of 2 sources. These are the same sources that sell cam cores to most every cam manufacturer out there, including the OE manufacturers. I can assure you that no “cheap” or overseas core is ever used in a Comp Cams product. When grinding a camshaft the core specifications must be as close as possible to the finished cam grind specs in order to maintain the deepest possible heat treat. That is why Comp has the largest selection of cam cores in the industry.
Comp maintains some of the highest quality control standards of any camshaft manufacturer in the world. Our cam grinds will be closer to the specs on your card versus any other grinder. We see less than 1% defect rates in our LS cams, which is lower than any other manufacturer that I am aware of. Also there has been no consistent heat treat issue of any type that I am aware of. This is not to say there has never been individual issues, but nothing that has been a continual issue. While it is certainly true that we are not perfect and we do encounter the occasional issue with one of our parts, we do try very hard to ensure that problems are very minimal and we have kept it at a level of less than 1% regarding LS camshafts.
Tolerances for our cams are:
Lobe Separation: +/- 1 degree
Advance: +/- 2 degrees if specified
Duration @.050: +2.5/-1.0 degrees
Lobe Lift: +.003/-.004
We do care about our customers and their projects because we rely on them for our livelihood. We strive to make the best performing and the longest lasting product possible. No company is perfect, but we do try. Also, if a customer has a problem with a product we do everything we can to help fix it.
I would also like to direct you toward a press release put out by Driven Engine Oil. It highlights the importance of proper engine oil especially in LS engines.
Driven Press Release
http://www.autopressreleases.com/vie...se.php?id=1324 "
__________________
Matt Maxwell
Technical Consultant
COMP Performance Group
That claim is 100% false. Their quality control is absolutely positively no where in the same remote galaxy as those figures.
My statement is based off of putting a degree wheel on 100+ Comp camshafts over the years. I could also rattle off 2-3 other WELL known engine builders in this country that would also solidify my information but I will not unless they want to offer it themselves. Not everyone is as politically incorrect as I am.
Old Apr 23, 2013 | 06:05 PM
  #65
Patrick G's Avatar
LS1 Tech Administrator
If all aftermarket cams were wearing out at the same rate, then I could see this being predominantly an oiling issue. But since there are certain brands of cams that are holding up very well to today's oils, it makes you sit up and take notice. That was the whole purpose of this thread. It was not "why are all aftermarket cams wearing out so fast these days?" If that was the thread title, then you could turn this into an oil thread. But premature wear and improper intake centerline grinding are not oil related. Not if other brands are unaffected.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old Apr 23, 2013 | 06:08 PM
  #66
Damian's Avatar
LSX Mechanic
Old Apr 23, 2013 | 06:11 PM
  #67
AmDWs6's Avatar
damn, this thread popped my eyes out.
i really don't think it's oil related though, i have to say this isn't the first time that i hear that comp cam's aren't that much as people are making them shine.
Old Apr 23, 2013 | 06:15 PM
  #68
babbage1109's Avatar
Makes me feel warm iniside about the cam I just put in my motor...
Old Apr 23, 2013 | 06:34 PM
  #69
RezinTexas's Avatar
so what are those of us with Comp Cams to do?
Old Apr 23, 2013 | 06:36 PM
  #70
03Sssnake's Avatar
^^^well apparently....pray for best
Old Apr 23, 2013 | 07:09 PM
  #71
3rdCoastPowerSports's Avatar
I think this thread is going to worries a lot of people unnecessarily. I agree that comps QC leaves alot to be desired but to have a thread that after a few pages basically has a conclusion that your comp cam is going to die soon is taking it to far. I understand Damien and a few others here are full time pro's and have lots of real world hands on experience and i very much respect their opinions/information and input. I SURE WISH A FEW MORE OF THE VENDORS/SPONSORS ON THIS WEBSITE WOULD CARE TO COMMENT ON THIS THREAD. I think we all know which sponsors need to chime in.
Old Apr 23, 2013 | 07:21 PM
  #72
Quick Ranger's Avatar
Yeah I can think of one sponsor I'd like to hear from...
Old Apr 23, 2013 | 07:37 PM
  #73
pauls99z28's Avatar
This Sux! now my H/C/I is on hold till i figure out this cam situation. vendors/SPONSORS please chime in!
Old Apr 23, 2013 | 07:46 PM
  #74
JakeFusion's Avatar
Super Hulk Smash
I know of one sponsor who probably sells more Comp Cams than all other LSX vendors combined. I will bet money they don't say anything other than "our cams are great!"
Btw, my cam is ground on a Cam Motion core.
  #75
Alvin@PCMofNC's Avatar
LS1Tech Sponsor
If it means anything to anyone we pulled 4 completely stock cams out of LS cars last year alone due to lobes being trashed. All of them come in with a miss that will not clear up and sometimes they have a tap that comes and goes every 30 seconds or so. 2 of those cars where never raced. Food for thought.
__________________
See what's in our shop on Facebook! Customer Build Blogs!
www.pcmofnc.com
Performance Installs - Dyno Tuning - Custom Camshafts & Valvetrain - Remote HPtuners Tuning - Mail Order Tuning & Sales
704-307-4227
Old Apr 23, 2013 | 10:47 PM
  #76
Damian's Avatar
LSX Mechanic
Stock cam damage does happen but it's a rarity in relative terms.. Usually when I see it, there's heavy indication that the entire top end was starved of oil due to previous owners not ever checking their oil levels.
Old Apr 23, 2013 | 10:58 PM
  #77
ds98formula's Avatar
Crazy. Well I hope mine stays together for a wile. 12k on it so far hope I got lucky. Really don't wanna swap out cams and tune again. If tune was not so much I would pull it just for peice of mind. Then again pulling the cam out just for anoyher one ground to same specs from different supply seems silly to me. When they go what do they normally take with them?
Old Apr 23, 2013 | 11:04 PM
  #78
Damian's Avatar
LSX Mechanic
That depends on the severity of the lobe damage and/or how long you let it ride making noise. If your valvetrain starts to gradually get louder for no apparent reason you've probably already got a chewed lobe and it's working on another one. If it goes too long and the lifter turns in the bore, you're in deep doodoo.
Anyone reading this thread should look into it if their Comp setups are getting louder for no reason. If you notice louder ticks than before or more overall racket coming from the engine, at the very least pull the intake manifold & valley pan to have a peak. You can see a few of the cam lobes through the valley.
Good luck gentleman. Use a zinc additive religiously, be aware of additional valvetrain noise.
Old Apr 24, 2013 | 04:10 AM
  #79
Jake, you are most likely thinking of the same sponsor i was, i will not be using that one now. Who uses Cam Motion? Maybe i'll look into FTI, i believe Ed uses Lunati.
Old Apr 24, 2013 | 06:27 AM
  #80
03Sssnake's Avatar
Futral, Spartan Performance and Engine Power Systems / EPS use Cam Motion cores. I am sure there are some I have not mentioned, though they do not come to mind at the moment.
