What's up with Comp Cams ?
Old Apr 24, 2013 | 06:59 AM
  #81
senicalj4579's Avatar
Originally Posted by Patrick G
If all aftermarket cams were wearing out at the same rate, then I could see this being predominantly an oiling issue. But since there are certain brands of cams that are holding up very well to today's oils, it makes you sit up and take notice. That was the whole purpose of this thread. It was not "why are all aftermarket cams wearing out so fast these days?" If that was the thread title, then you could turn this into an oil thread. But premature wear and improper intake centerline grinding are not oil related. Not if other brands are unaffected.
This is how I thought also. We should have seen other cam fail too.
With that being said, I hope my comp cam hold up
And still nothing from OP.
Old Apr 24, 2013 | 08:46 AM
  #82
gagliano7's Avatar
Real oil test http://www.triumphspitfire.com/Oiltest.html
Old Apr 24, 2013 | 09:28 AM
  #83
JakeFusion's Avatar
Super Hulk Smash
I think the point is in a street car built for reliability and longevity, oil, as long as its good enough, won't make a difference. But a performance built engine revving to 7k is something else entirely. Because "good enough" is beyond what most oils provide.
Old Apr 24, 2013 | 10:53 AM
  #84
badamn's Avatar
Originally Posted by 87silverbullet
Read the link I posted earlier. There are brands out there with less ZDDP and work beautifully because of their sheering factor. Look at what oil made #1. It only had 806 ppm of zinc compared to the rest. Its capability to protect against metal to metal contact is why it made #1. As I said before Valvoline VR1 10w30 conventional or synthetic is the best in my eyes. I do agree with you though on regular oil change intervals and so forth but no matter 100 miles or 3000 miles, wouldn't you want the best in there?
Well if cost wasn't a factor then yeah.
Old Apr 24, 2013 | 02:38 PM
  #85
pauls99z28's Avatar
Well im done! Just shipped my comp cam back to the vendor for a refund.
NO MORE WORRIES!!!
Now back in the hunt for a Cam!
Old Apr 24, 2013 | 05:48 PM
  #86
jmargo's Avatar
Originally Posted by pauls99z28
I would like to share a reply from Comp Cams to my questions about type of Material,Tolerances, and Concerns we normal folk have..lol.
Take note of the link at the end of the reply. hope this helps
Here goes...
"Hello Plustiano and thank you for signing up on CPG Nation!!!
Comp Cams uses various materials to make camshafts depending on what is best for that individual engine and application. We use a wide array of materials due to the fact that we cover a very wide variety of engines. Austempered cam cores are not used in LS applications nor have they ever been by our company. Our LS cams are made predominantly from 5160 or 8620 material. Either the 5160 or 8620 material is more than capable of handling any Hyd. Roller LS application. The difference in materials used has no effect on quality control what so ever and I am not sure what would lead you, or anyone else, to believe that it would. Also all of our cores are produced in the US and come from 1 of 2 sources. These are the same sources that sell cam cores to most every cam manufacturer out there, including the OE manufacturers. I can assure you that no “cheap” or overseas core is ever used in a Comp Cams product. When grinding a camshaft the core specifications must be as close as possible to the finished cam grind specs in order to maintain the deepest possible heat treat. That is why Comp has the largest selection of cam cores in the industry.
Comp maintains some of the highest quality control standards of any camshaft manufacturer in the world. Our cam grinds will be closer to the specs on your card versus any other grinder. We see less than 1% defect rates in our LS cams, which is lower than any other manufacturer that I am aware of. Also there has been no consistent heat treat issue of any type that I am aware of. This is not to say there has never been individual issues, but nothing that has been a continual issue. While it is certainly true that we are not perfect and we do encounter the occasional issue with one of our parts, we do try very hard to ensure that problems are very minimal and we have kept it at a level of less than 1% regarding LS camshafts.
Tolerances for our cams are:
Lobe Separation: +/- 1 degree
Advance: +/- 2 degrees if specified
Duration @.050: +2.5/-1.0 degrees
Lobe Lift: +.003/-.004
We do care about our customers and their projects because we rely on them for our livelihood. We strive to make the best performing and the longest lasting product possible. No company is perfect, but we do try. Also, if a customer has a problem with a product we do everything we can to help fix it.
I would also like to direct you toward a press release put out by Driven Engine Oil. It highlights the importance of proper engine oil especially in LS engines.
Driven Press Release
http://www.autopressreleases.com/vie...se.php?id=1324 "
__________________
Matt Maxwell
Technical Consultant
COMP Performance Group
He replied to you in this thread and then agrees with two other posters that their cams are 6 degrees and 4 degrees off.
http://www.cpgnation.com/forum/6-deg...rded-8400.html
http://www.cpgnation.com/forum/cam-d...tion-8309.html
Looks like I will either buy a degree wheel or see if someone can loan me one for my cam swap.
Old Apr 24, 2013 | 06:16 PM
  #87
pauls99z28's Avatar
that is why i decided in order to eliminate the doubt i just wont use a comp cam grind. It sucks but when thousands of dollars is on the line theres no room for taking chances.
Old Apr 24, 2013 | 06:17 PM
  #88
LilJayV10's Avatar
8 thousand miles on my Comp cam...
Old Apr 24, 2013 | 06:19 PM
  #89
LilJayV10's Avatar
I was also told that Comp does not recommend using synthetic oil with their cams, even rollers.
Old Apr 24, 2013 | 06:36 PM
  #90
Theres 10k on my cam. This thread is making me sick
Old Apr 24, 2013 | 07:47 PM
  #91
MazantMule's Avatar
Yeah comp cam just cost me thousands of dollars had a failed cam with less than 15000 miles had to refresh the entire motor I am now going with cam motion.
Old Apr 24, 2013 | 08:03 PM
  #92
Quick Ranger's Avatar
Vendors out there that are still using Comp to do their grinds had better change, this thread has totally moved me away from using a comp product, period.
Old Apr 24, 2013 | 08:19 PM
  #93
ds98formula's Avatar
i will pull my intake and vally cower sat or sunday. if ever thing looks good I will count my self lucky and if not then I will cross that bridge when I get there. God i hope not though I really like my cam and would hate to have to pull it install the same grind just diffrent supplier and be out money for a cam a retune.
Old Apr 24, 2013 | 08:28 PM
  #94
LilJayV10's Avatar
Originally Posted by bozzhawg
What lobes?
They are the lobes Geoff uses for his EPS cams.
Old Apr 24, 2013 | 08:29 PM
  #95
LilJayV10's Avatar
I assume they didn't help out towards the cost of the rebuild?
Old Apr 24, 2013 | 08:31 PM
  #96
WTF....so anyone here who has had a comp cam installed within the past year that has had no problems? Im not liking this at all.
Old Apr 24, 2013 | 08:49 PM
  #97
badamn's Avatar
the solution for comp is to put a something,thousand garuantee on their cams,till then they deserve this serious burn.
Old Apr 24, 2013 | 09:50 PM
  #98
MazantMule's Avatar
To be honest I never contacted them about the matter but I am more than sure they would not the part that have me so angry is this is from a previous fresh build which I spent thousands of dollars only for this to happen the cam was great performance wise it was a stroker V.3 247/251 but the word around is how comp cams has Ben causing a lot of people the same problem I will just have to take it as a loss and lesson learned.
Old Apr 24, 2013 | 10:13 PM
  #99
jt76's Avatar
I had a comp 231/237 cam in my car for 5 years and almost 25k+ miles and it looked fine when it came out. I currently have a speed inc TU1 which i believe is a comp cam. 6k miles in and seems ok... knock on wood.
Old Apr 24, 2013 | 10:14 PM
  #100
chrs1313's Avatar
Hmm this isn't good...kind of disappointing all this is finally coming out now...
At least Damian has the ***** to step to the plate, not like others who have been hush hush or turned their head
