Hot cam results
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
Just as a side note. Mine has been in since June 2003 and about 20K miles. Nothing but routine maintennce on the car. When the cam swap happened I did chjanged just about every maintenance item:
ASP Pulley
Oil Pump
Timing chain
Valve seals
gaskets
thermostat
LS6 intake
Hotcam kit
All were done at the same time. Stock pushrods. All were straight so they got re-used. I fugured if it came off the car, I wanted new going back on.
I got 24.5 mpg between Stl and Springfield, MO with 4.10 gears, and running at a pretty good clip.
ASP Pulley
Oil Pump
Timing chain
Valve seals
gaskets
thermostat
LS6 intake
Hotcam kit
Read the contrary here from users. That camshaft requires free flowing exhaust.
awesome
ima have to change my shift points now.. iv really been looking for a dyno chart graph on a LQ4 with hotcam, but wouldn't think itd be much different a ? iv got my 1-2 shift set @ 6700 2-3 @ 6400 im thinking now maybe just go with 6400 across the board but idk, does the truck intake make that much difference ?
And my afr is in the 11s from WOT maybe i should bump that up to 12.5 r so too
![Mr. Cool](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cool.gif)
