Place to buy heads on a budget
Old May 3, 2013 | 11:05 PM
chevyforlife's Avatar
Default Place to buy heads on a budget
I'm looking for a place I can buy a set of reman 317 heads for a reasonable price or even a set of aftermarket heads I'm on a pretty tight budget I'm just looking for something with a 72 cc chamber and comes with valves I have springs already any sponsors or websites you guys can think of would be really appreciated
Thanks
Old May 3, 2013 | 11:20 PM
Dmitriy's Avatar
Texas Speed has great deals - ebay has super cheap ported heads, but thats your risk to take.
Old May 3, 2013 | 11:25 PM
HCI2000SS's Avatar
+1 on Texas Speed for good budget heads. I think my 5.3's were like $1300 complete
Old May 3, 2013 | 11:32 PM
Ya that's the one place I was looking so far they do seem to be priced really good
Old May 4, 2013 | 02:18 PM
2000PewterT/A's Avatar
Texas Speed has great prices on heads
Old May 4, 2013 | 02:30 PM
Anyone know if the prc stage 1 cnc ported heads are any better then stock heads?
Old May 4, 2013 | 02:33 PM
HCI2000SS's Avatar
PRC stage 1 LS6 heads vs stock LS1 heads. If so then yes they will make more power
Old May 4, 2013 | 04:09 PM
WS6ICK2k's Avatar
You might want to look into the PRC 225s as cast, they flow great and have more potential down the road for CNC porting. I think there around 1500-1600 range. But I am not sure if you are going the boost route with 317s.
Old May 4, 2013 | 04:10 PM
LilJayV10's Avatar
What's your budget?
Old May 4, 2013 | 10:36 PM
leeluther252's Avatar
The stage 1 is a fully ported head. The only difference in stage 1 and 2.5 is valve size and roughly 5hp. So yes they are way better than stock heads
Old May 5, 2013 | 03:59 AM
Quick Ranger's Avatar
If you are just looking for a stock reman head, Thompson Motorsports sells those. I've seen ads on ebay, even the 243 heads are only 599, not too bad considering most used 243's go for 4-500.
Old May 6, 2013 | 01:05 PM
thompson's Avatar
^^^We also have our aftermarket castings with high grade aluminum, bronze guides, CNC work on runneres and chamber and much more starting at $1349.
And to touch on the response above yes we do have reman 243/799 heads starting at $599.
Give us a call and we will help you find what you are looking for.
Old May 6, 2013 | 01:16 PM
Blackpanther99's Avatar
Got mine from Ebay with 0 issues, but its a risk.
Old May 6, 2013 | 01:41 PM
JakeFusion's Avatar
Super Hulk Smash
That's cool on the reman heads from Thompson for 599.
The 243s are worth 20HP over LS1 heads. But against the 317s, there isn't much difference - maybe 5HP due to increased compression; it's the same head.
The TSP Stage 1 would probably be up about 25-30HP over stock 243s. So you might see closer to 30+HP on an LQ9.
Old May 6, 2013 | 02:00 PM
I'm boosted that's why I'm going with 317s and honestly my budget is less then a grand cause I still got other stuff I gotta get
Old May 6, 2013 | 04:22 PM
thompson's Avatar
317s on boost will work great.
