DAMN LS2 cam position sensor!!!!!!!
Old Apr 25, 2006 | 07:43 PM
Orange Peel's Avatar
Smile DAMN LS2 cam position sensor! FIXED!!!
I bought a new one today, replaced the sensor and STILL have no tach and the hard starting!!!!! I reversed the wires AGAIN back to the way it came on the male ended plug that goes into the sensor, STILL have no tach and still hard to start. I switched them BACK to the suggested swap way again and it's still the same.
My next step is to pull the harness and check it, but it's SUCH a pain in the *** to get to on the back of the intake area. What the hell is going on? Bad harness maybe??
Why me!!!!?
Old Apr 25, 2006 | 09:34 PM
Katech_Jason's Avatar
LS1TECH Sponsor
Why me!!!!?
What cam gear are you using?
Old Apr 25, 2006 | 09:47 PM
Florian's Avatar
CKP relearn.
F
Old Apr 25, 2006 | 11:32 PM
LS2 cam gear with a JWIS chain.
My tuner said a crank position relearn isn't neccessary and the car would throw a code for that.
Old Apr 25, 2006 | 11:50 PM
-Joseph-'s Avatar
LSxGuy widda 9sec Mustang
I've been connecting directly into the sensor itself, but with the outside 2 wires crossed. If you get the extension harness from Speartech or Racetronix this is already done though, if you lengthen it yourself then you have to swap those two wires at the connector. I havn't done one in a few weeks but I think its pink and brown that get crossed, I can check in the morning and see which go to which Pin location.
Are you using also using the C6 harness in-line, it comes with most LS2 timing covers, about a 4" harness built onto the cover?
Old Apr 26, 2006 | 12:13 PM
I'm using the Racetronix extension harness and I tried it with the wires left alone like how they come with the harness, no dice, then I swap the outer two like everyone says, the brown and red wires, still no dice.
Tired a new sensor, no dice. I took the extender harness off that came with the cover that moves it down to the bottom of the cover, and plug directly into the sensor, no dice.
I'm running out of dice here people Could my harness be no good?
Old Apr 26, 2006 | 12:16 PM
LS1TECH Sponsor
What year LS2 cam gear?
Old Apr 26, 2006 | 01:10 PM
I don't know, I just called my parts dude and told him I needed a LS2 cam sproket, and he got me one.
Combination installed everything and if it wouldn't work I think they would have known or said something.
Is there a difference? What about sensors, different years get different sensors too? I ask because the one that came with the cover was tan/grey colored, the new one I ordered was black with different numbers on it.
Thanks for the help!!!!
Old Apr 26, 2006 | 01:16 PM
Ok, I got my receipt for the parts I ordered, here's the part number for the cam sprocket....
12586481 - LS2 cam sprocket
The number on the cam position sensor that came with the LS2 front cover I ordered is.... 12585545.
The new one I installed yesterday was black and had a different number on the top, not sure what it is right now.
Old Apr 26, 2006 | 02:32 PM
LS1TECH Sponsor
You need the 2005 Cam sprocket. 12576407
You got the 2006 sprocket 12586481
2005 left, 2006 right
Photo courtesy of LS1tech user: billreid1@***.net
Problem solved
Old Apr 26, 2006 | 02:44 PM
Oh **** me! Can't I just get the correct sensor??
Old Apr 26, 2006 | 03:17 PM
LS1TECH Sponsor
Nope, your PCM needs a 2x signal
Old Apr 26, 2006 | 03:18 PM
Man life can't get any better than this! Well, I DO thank you a TON for helping me figure it out, now I just have to get that sprocket and change it out, how fun!!!
Should I use the orginal sensor that came with the LS2 cover and not use the new '06 black sensor I got?
Old Apr 26, 2006 | 03:36 PM
LS1TECH Sponsor
12568983 has been superceeded to 12555545. Either will work.
Old Apr 27, 2006 | 12:04 AM
Jason, you are the man!!! I got the '05 sprocket like you said, put it in tonight and it fires right up, got the tach working again and things are PERFECT!!! I swapped the wires back to how they came on the Racetronix cam sensor harness and it's awesome!!!
I left sponsor feedback for you guys, you REALLY know you stuff dude, and I thank you for taking the time to help me out!!!
Old Apr 27, 2006 | 07:48 AM
LS1TECH Sponsor
Sweet! I'm glad to see you got it fired up.
Old Apr 27, 2006 | 12:54 PM
Beast96Z's Avatar
In no way shape or form can you beat the help we get here. The only thing that would be better is if they came to your house and did it for you.
Old Apr 27, 2006 | 01:14 PM
Agreed 110% my friend!!!!
Old Apr 27, 2006 | 01:16 PM
GuitsBoy's Avatar
One more thing to remember for when the time comes... Glad you got it sorted out.
Old Mar 3, 2013 | 10:25 PM
Schwarzer's Avatar
I'm reading every cam position conversation I can find. I have an 02 SS getting a P0343 code, hard starting and no tach. Changed the sensor a couple times, traced the pink and brown wires to the PCM and they are good. I can't tell where the red wire from the plug goes to. I'm completely torn apart now and want to hear any ideas before I put it back together. I had a comp cams xer281hr put in and everything worked for 1000 miles after the swap before this issue came up. Please help
