How much HP can a stock 6.0crank hold?
How much HP can a stock 6.0 crank hold?will it hold 550 hp plus a 300 NO shot?This is for 1/8 dragracing only!!
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
6.0 crank is the same as the 5.7 except its not hollow in the center sections. According to valvegod it weighs 1.7 lbs more than the 5.7. Since there is added material to virtually the same crank...it should be a tad stronger and a tad stiffer too. I ran a stock 5.7 crank for 1 1/2 years at the 700+ rwhp level so the 6.0 should easily hold that.
THANKS 383LQ4SS!!!! I knew somebody has tried it! I was talking to a guy at the local speedshop (he works there)and he said he was running a cast crank in his 408 Mustang with a 2 stage 300 hp shot of NO.I have seen his car at the track it runs 5.3 to 5.6 in the 1/8 mile at 125 mph!!Now I have never been a nitrous fan but after seeing it run I have changed my mind!!!! This same car has a hydralic roller cam!Oh yea it weights 3000lbs,I'm still not a Ford fan!
![Hail](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_hail.gif)
