Throttle Response (I need some)
I am looking to get the most throttle response out of my new motor as possible. My motor is going into a new rock crawler buggy and the more “snappy” the motor is the better. Here are specs on motor
LQ4 with complete rebuild
stock pistons
317 heads milled .35 w/ valve job
Heads ported and polished, they now flow 290 CFM
Texas speed 224 224 112 cam
Ceramic coated block hugging headers
Stock truck intake
Holley EFI HP system
What do I need to do to get the most Throttle response out of this motor? Port intake, underdrive pulleys,…
http://www.chevyhiperformance.com/te...e_compression/
http://www.popularhotrodding.com/eng...ression_ratio/
Calculators - I believe cranking pressure is better "real world" information...
http://www.csgnetwork.com/compcalc.html
http://www.wallaceracing.com/dynamic-cr.php
I added a 102 tb among other things and it would bog and be slow to rise in RPM. Timing is the key here. I added timing to the idle and main spark tables in the 1200-2000 rpm areas. The motor REALLY woke up. If you can take a little bucking at light throttle you can go pretty far with the timing. IE mid 20's and it will feel very "snappy".
What are the chamber cc with a .035 mill? Ideally you'd want around a 8.5 DCR and 11.5 SCR which is fine on pump gas with the proper cam and quench.
