Cam only ok ??????
Old May 19, 2013 | 09:08 PM
PREDATOR-Z's Avatar
So to all the bright lights out there, if 3/4 race cams exist they must have a parameter. Logic?
Give me the parameters of a full race cam?
And BTW guys, I'm 50 so it is old school enough.
(Between us, it was just a term used back in the days where dumb asses couldn't explain that they have inside their motor)
Old May 20, 2013 | 08:55 AM
DACTARI's Avatar
Not everyone can be Predator-Z. I don't mean this facetiously.
Old May 23, 2013 | 07:52 AM
Sales@Tick's Avatar
Predator Z>all.................
Hi Mark!
Old May 23, 2013 | 08:10 AM
alans02z's Avatar
I think the guidelines are something between a rv cam (1/2) and a race cam (1).
Best I can tell is a 3/4 race cam is a super badass lopey awesome kick you in the nuts street car cam.
Old May 23, 2013 | 10:26 AM
Marc 85Z28's Avatar
How dare you claim to be a camshaft afficianado.
Old May 23, 2013 | 10:48 AM
PREDATOR-Z's Avatar
So a shop had a marketing gimmick targeting said above dumb asses!
Old May 23, 2013 | 10:53 AM
Rob WS6's Avatar
As legend has it, the 3/4 referrs to 3/4" of lift, or as we would know it today, .750".
Old May 23, 2013 | 11:10 AM
flattusmaximus78's Avatar
If you run no cam at all, there is a lot less drag on the engine. My .02 cents.
Old May 23, 2013 | 11:29 AM
PREDATOR-Z's Avatar
So in your opinion a .750 lift cam is a mild street performance cam?
Ok, so according to your legend, if .750 lift is 3/4 then the full race is 1 inch lift? Please try to visualize 1 inch lift. Ok now try putting that in a stock 350 sbc.
Old May 23, 2013 | 12:24 PM
03Sssnake's Avatar
I have some old uncles that ramble on about 3/4 and full race cams, makes me scream inside, but I stay calm and respectful while they spew their BS.
Old May 23, 2013 | 12:58 PM
Marc 85Z28's Avatar
Aftermarket performance 50+ years ago was VERY different from today. 3/4 race was a nickname used if you were lucky enough to own an engine that had aftermarket camshafts available. The "3/4 race cam" was eventually offered to fill the gap were a "semi-race" and "full race" cam was already available. Like the Mopar "purple" cams, the "30/30 cam", and more recently the "CompuCam" and Ford "letter cams". Numbers fade with time but the names stuck.
The point is, while the name doesn't divulge the specs, it certainly doesn't change the FACT that they existed, AND STILL DO. Those Crane Energizer lobes are probably older than you!!
If someone tells me they had an old 327 with a double pumper, Offy manifold, camel humps, pop up pistons, 30/30 cam and Tri-Ys I don't roll my eyes. Because that's what they had 40 years ago!
Edit: So do you get all bent out of shape when someone comes on this site asking about a Magic stick or a Trex?
Old May 23, 2013 | 02:24 PM
  #32
PREDATOR-Z's Avatar
For street, Nahh, not anymore; boys will be boys
I just spank them
Old May 23, 2013 | 05:02 PM
  #33
Sales@Tick's Avatar
I would think it refers to advertised duration, not lift. My .02 cents.
Old May 23, 2013 | 05:08 PM
  #34
madmike9396's Avatar
I prefer the 15/16 grind cam
Old May 23, 2013 | 05:56 PM
  #35
1BAD98LS1's Avatar
Originally Posted by JudgeGuns
prob have 250 600 114 cam and yeah headers are on order
guess i could say stage 2 or stage 3 cam? lol
250 is quite a lot of duration, .600 isn't much lift.. so if your going that route you should get 1 7/8" headers and at least a FAST 90 intake although 102 would be better.
Old May 23, 2013 | 10:28 PM
  #36
Rob WS6's Avatar
It was a joke man.
Old May 23, 2013 | 11:03 PM
  #37
PREDATOR-Z's Avatar
It was a joke man.
Come on, play along will you?
