New JD motor lets go after only ~1500 miles
#43
Originally Posted by StevieZ
What were the internals? Stock rods and crank?
said stock crank and rods with ARP bolts. Wonder if it was a wristpin that broke...
#49
Ez just wash your hands of it and give APE a call, they are somehow managing me even after all my dealings with JPR (ie trust issues with everything car related now). I talk to Chris almost everyday and they are willing to stand behind their work 100 %. Cool guys at the APE shop. Keep up the good work guys, maybe you can start a JPR/JD relief center .
#50
Originally Posted by Chris ARE 360
man oh man...
I feel for you man... How much total do you have tied up in this mess now?
#51
Originally Posted by Chris@AP-Engineering
Stock rods are the weak link in this build. I would not worry about the stock crank, they have held up great so far. The rods I would be worried about though.
Stock rods, stock crank, arp rod bolts, most everything else aftermarket (lifters, bearings, pistons, piston rings, pushrods, rockers, etc..)
#52
Stock crank and rods are normal for a "budget" all bore. Most upgrade the rods though. Stock crank is very strong and will live forever under 7400rpm with the right setup
#54
You'll be able to determine what happened and what is in it when you take it out and apart. What are your plans now with the car ezss?
Well the car was towed to Mikey @ rapid motorsports. He will take a look at it, see whats salveable and what happened, and ill go from there. Im not in the financial bind I was before, so although it wont be popular with the other household member, I can probably put some money into the car again to get it where I want it to be. If the block is toast I do not think I will go with another increased bore setup -- I may go back to stock cubes and do a budget shortblock or I may do a 383 stroker setup if it looks feasible. All depends on what it looks like.
If the block is salveable I would like to send it to Steve @ race eng (who does the APE setups and co-designed the darton wet setup) to take a look because he was super helpful to me before and knows these blocks better than anyone else inmho.
Im still a little stunned by the whole situation, but thanks everyone so far for the support -- makes it easier for me to want to get back into the car.
#55
LSX Mechanic
no actually thats racing
#56
#57
Originally Posted by SAM98WS6
Erik, sorry to hear that bud. Good luck and I would not hesititate to go with the AP Eng guys based on thier customer commitment displayed on this board.
Hope we get to line them up sometime. If mine goes there is no one to blame but myself
#58
ezss,
I'm sorry to hear about the motor and jope you get back up and running soon. I have a ton of respect for Mikey, good guy and knows his stuff. If you towed the car back to him why not sit down and let him make a few suggestions.
On another note, I keep asking about these Darton wet-sleeve motors and reliability and no even speaks about them anymore. This is the 4th one I have directly seen or heard about coming apart in very short order. If your motor is locked up it sounds to me like the cylinders are full of coolant. I still have problems believing that these blocks are proven rliable or even close as yet
#59
Originally Posted by Damian
That's the biggest bunch of **** i've read in this thread yet. JD/JPR hasn't been capable of building this man a motor to last 5 minutes. Thats not racing, that POS workmanship...If this motor would have lasted at least ONE full season and then blew up.............Yes, that is called RACING.
#60
Originally Posted by Warbird
ezss,
That leads me to believe the rotating assemblies and top end were not assembled properly, not the blocks.
