Max lift for 100K mile longevity
Old May 15, 2013 | 04:06 PM
badassracing's Avatar
I personally had a 99 Z28 with a TR224/224 .563/.563 that had 100k on it with comp beehives. Thats 100k after cam swap.
Old May 15, 2013 | 04:09 PM
outkast6991's Avatar
You should buy some powerball tickets cause you are pretty lucky
Old May 15, 2013 | 04:10 PM
JakeFusion's Avatar
Super Hulk Smash
Did you have 100k on the beehives too? If so, HOLY GOD.
Too bad TR is shut. The TR224 is a good little cam.
Old May 15, 2013 | 04:13 PM
Yep 100k on the same beehives and it was abused...and abused...and abused!! The only reason it stopped there was because it spun a rod bearing. Cam looked good when it was pulled but went with a stroker and bigger cam.
Old May 15, 2013 | 04:16 PM
Doesn't a stock ls6 come with .550 lift? I'm not really sure how an extra .013 lift would shorten the life of springs as much as everyone on here claims.
Old May 15, 2013 | 04:34 PM
JakeFusion's Avatar
Super Hulk Smash
It has little to do with lift (unless you're in coil-bind all the time). It's the ramp of the cam lobes...
Old May 15, 2013 | 04:39 PM
I guess I could be wrong but I would think the amount you compress the spring would be harder on it than how fast it happens. I dont know how fast the ls7 valves open but I would think they open pretty quick with 1.8 rockers..and they have .590 lift right.
Old May 16, 2013 | 10:39 AM
D_Eclipse9916's Avatar
Is that because of the beehives or simply because of aftermarket steel springs? I would think a decent aftermarket dual steel spring would be able to handle a 224 or 228 cam pretty easily for a long time.
Old May 16, 2013 | 11:56 AM
low2001gmc's Avatar
MASS seller approved
Originally Posted by Bowtie316
Definately!
The cam I was going to use has more lift but less duration. It’s a lunatic voodoo 217/223 .549/.549 lsa113, but I started to wonder if I could get away with the EPS truck torque 2 or something similar.
Great information on valvespring maintenance. That is plenty doable if it keeps the motor alive.
I had heard great things about VR1 but I already bought some Rotella T-6. Any idea where that falls on the cushion chart?
pac1218s i would say for under 590 lift and pac1518s for 590-625 lift. psi ml1511s are also very nice and what i use. lightweight titanium retainers also help and i use them also. as for oil, im gonna start using valvoline vr1 10-30 based on recommendation of tick and now on here from jake fusion, just not due yet but soon.
Old May 16, 2013 | 10:37 PM
JakeFusion's Avatar
Super Hulk Smash
LS7 still has mild lobes. It also has about as much lift as an XE-R camshaft. Guess which one is warrantied to last 60k miles?
Old May 17, 2013 | 07:15 AM
Bowtie316's Avatar
So LS6 cam, 5/16 .080 hardened push rods, with LS6 springs, should still probably be checked or replaced at 50k to be safe.
.550 to .600 XE-R, LXL, LSL 11/32 push rods, PAC 1218 springs, check and/or replace at 30K or yearly whichever comes first.
I think I'll just go ahead and do the Pat G cam recommendation and see what he comes up with. I wonder if he will recommend the other valvetrain components as well?
Old May 17, 2013 | 04:57 PM
  #32
I never said anything about xe-r lobes. I was talking about lift in the mid .500s with milder lobes than xe-r.
Old May 19, 2013 | 10:16 AM
  #33
Bowtie316's Avatar
Patrick G came back with this cam recommendation.
220/226 .604”/.604” 113 LSA +2 advance (with 1.7 ratio rockers)
using EPS HiRev lobes.
Recommended valve springs: PAC 1218 or 1518 beehive.
It's just a little bigger than I was originally thinking. I'm just going to go with this and see how it turns out.
Old May 19, 2013 | 04:16 PM
  #34
CaliboyTA's Avatar
my car has 66k miles on a torquer 2 (232/234 .595/.598 112 lsa ) with ls7 lifters, stock length tsp pushrods, prc dual springs .650 lift and i have no problems with the car
Old May 19, 2013 | 04:31 PM
  #35
garygnu's Avatar
will a GM ASA cam live for 100k with stock GM springs ?Damian has a good cam that was easy on springs ,and it made great power.you would need comp 918 springs.maybe use stock rockers with trunnion upgrade bearings.
Old May 19, 2013 | 08:24 PM
  #36
96capricemgr's Avatar
Didn't break a spring does NOT mean it was still working right..........................
Old May 19, 2013 | 08:37 PM
  #37
HoLLo's Avatar
I'm running a Patriot 225/229 .580/.590 114+4 cam on PAC 1218 .600" lift springs with over 30k miles so far, still runs great.
Old May 21, 2013 | 04:24 PM
  #38
Maybe not but it always put down the same 1/4 mile times.
Old May 21, 2013 | 05:11 PM
  #39
SNLPerformance's Avatar
Ok,
Stock will go 100k +
However, if you are doing all this to your car it is the name of the game to have to replace components that wear.. Springs, especially dual sets will wear out around 15-20k depending on lobes/use. For the price of springs why would you want to run them until they could potentially break. A set of BTR springs are around $219-300 on average. Why would you want to cost yourself a motor over trying to get by with not spending money on replacing crucial parts. Sure you can run some beehives further but why would you want to sacrifice power/cam choice based on a set of $250 valve springs.
Even if they are not broke, they still "wear" out. Just my opinion, take it how you want.
Old May 24, 2013 | 12:41 AM
  #40
killernoodle's Avatar
LS6 cam and springs will last 100k miles because they are from a production engine designed to last 100k miles.
You might get 30-50k miles out of an aftermarket spring with an aftermarket, mild lobe.
I just took apart my 125k mile LS6, had a broken valvespring for who knows how long. Luckily it broke towards the top and was still able to keep the valve closed at redline
From now on, I'm going to change my springs every 30-40k.
