One LS7 Lifter has no Springiness, Has it Failed?
Shouldn't lifters have spring to them regardless of whether they are "pumped up" with oil? Does this indicate a failed lifter???
Can you look in and see if the plunger is up at the snap ring with no pushrod in place?
See what's in our shop on Facebook! Customer Build Blogs!
www.pcmofnc.com
Performance Installs - Dyno Tuning - Custom Camshafts & Valvetrain - Remote HPtuners Tuning - Mail Order Tuning & Sales
704-307-4227
I'm guessing it will just be super noisey with all the space between the rocker and the valve stem until if/when it pumps back up?
So if I run it down until the rocker touches the valve for zero lash or a little tighter, do you think that the lifter will be able to pump back up? If it does pump back up and expand back out, then I guess it would be the same as the pushrods being too long, right?
What risk am I running with no lifter spring flex? It almost seems like a solid lifter. Is this much harder on the cam and the rockers?
When I dissasembled it I found that the spring was smashed and the bottom end was hooked onto itself so that it was shorter than the others.
I unhooked it and stretched it out to the correct length but when I reassembled it, the plunger did not slide down easy, but ground on the way down, and is still stuck down to the bottom just like before. So, this lifter did indeed fail and a new one is going in.
The photo shows the smashed LS7 spring on bottom, a normal LS7 spring in the middle, and then a LS1 lifter spring on the top. The LS7 springs are longer than the LS1 springs, but the LS1 springs are thicker and beefier, which surprised me.
