LS1 rods and piston differential
Old May 15, 2013 | 02:06 PM
lofjussi's Avatar
Default LS1 rods and piston differential
I just repair my 98 trans am. 1st cylinders rod bearing is clearance and engine knocking. It s open bearing is broken only first cylinder. I bought car and give with new piston/rods bearing and shaft too. But piston/rods are little different. Which is better? Clean parts are new and oiling parts are too good condition. Sorry no picture... How I can add picture?
Old May 15, 2013 | 02:07 PM
thompson's Avatar
Look into purchasing a new short block, As long as you are using the 98' block you will be dealing with oiling issues. Call us if you need help finding one.
972-853-0518
Old May 15, 2013 | 02:40 PM
3rdCoastPowerSports's Avatar
972-853-0518
Happen to know the block casting number that "has oil issues"?
Old May 15, 2013 | 02:59 PM
lofjussi's Avatar
front of engine 61091 and rear 12559378 and 5.7 L
I dont have new block, only this ...
Old May 15, 2013 | 04:00 PM
I could be wrong but from what i understand the 12559378 block is the 99'-00' block used in the corvettes (im sure other apps as well). I was under the impression that only 97' & 98' LS1 blocks had the oiling issues.
Can a sponsor or other hands on experienced user confirm this?
Old May 15, 2013 | 04:06 PM
Monzsta's Avatar
Copied from Engine Builder...
http://www.enginebuildermag.com/Arti...all_block.aspx
1997 -'04 - 5.7L Cars
All of the 5.7L blocks are aluminum castings and they're all very similar, but there are a couple of subtle differences between the early ones and the late ones.
The 1997-'98 blocks with the 12550592 casting had two holes for the oil galleys that were flush with the back of the block itself, so the right lifter galley was fed by a shallow crossover in the back cover. These blocks also had a 24.5 mm hole drilled straight through the main webs to allow better "bay-to-bay breathing."
GM discovered during dyno testing that there was too much pressure in the crankcase due to the amount of air and oil vapor that was trapped between the main caps, so they drilled a hole through all five bulkheads to allow the engine to "breathe" from one bay to another. That eliminated the pressure build-up that was causing some internal problems.
GM used several castings for the LS1 motors from '99-'04, but they're all pretty much the same so it doesn't really make a lot of difference which one you use. However, there are a couple of changes that make each of them slightly different.
The right front corner of the block was reinforced in '99 and there was a deep oil slot added to the back of the block to allow more oil to flow to the right hand lifter galley. Look for a 12559378 or a 12560626 casting.
The 1256118 casting was originally designed for the high performance LS6 that was introduced in '01, but it showed up in some LS1 applications in '01 and '02 and it was used for all the Corvette motors in '03 and '04. The only difference between it and the previous block was the addition of two cast slots in each of the three center mains. They replaced the holes that were drilled through the bulkheads on all the other '97-'01 blocks.
Old May 16, 2013 | 06:15 AM
lofjussi's Avatar
Hello
I am from Finland and english is it not so clear...
What modification I have to do my block(12559378)? I understand that this is better block and without modifications or am I right?
And piston/rods, which is better (picture original message) left or right?
Thanks for help!
Br. Jussi
Old May 16, 2013 | 10:42 AM
thompson's Avatar
The blocks have a clock on them in the front window that will show the date built. 97-00 are problematic. If it does not have a date it is more than likely 05+.
Old May 16, 2013 | 01:29 PM
lofjussi's Avatar
Soon is the time to assemble engine. Pistons in first message: Is that right side late model piston/rod? Which is better with supercharger?
