Are Lifters recommended when installing a ms3 cam
Old Jan 12, 2014 | 01:18 AM
Baconz28's Avatar
My vote goes to brian tooley valve springs. All his name parts are great
Old Jan 12, 2014 | 01:26 AM
Burken01's Avatar
Who's talking about valve springs?
Lol
Old Jan 12, 2014 | 02:21 AM
Baconz28's Avatar
I meant lifters lol he also http://cdn2.bigcommerce.com/server49...01.450.450.JPG lifters.
Old Jan 12, 2014 | 03:17 AM
Burken01's Avatar
Lol don't trip chocolate chip I knew you meant lifters..
Old Jan 12, 2014 | 08:23 AM
Baconz28's Avatar
Lmao^^ working 14 hour days will drive you crazy bro
Old Jan 12, 2014 | 08:52 AM
Jimbo1367's Avatar
WTF? You DRINKING again?
Old Jan 12, 2014 | 09:57 AM
Baconz28's Avatar
I have read up on the btr lifters vs the ls7 lifter. Ls7 lifters have a problem with (leak down) which causes a ticking sound. Brian lifters are designed to prevent that and also they are forged which probably means they are a lot tougher in the long run.
Old Jan 12, 2014 | 01:14 PM
Burken01's Avatar
I hear ya I work like a slave too
Old Jan 12, 2014 | 01:15 PM
Burken01's Avatar
Too many energy drinks makes me twitchy....
Old Jan 14, 2014 | 01:30 PM
Siciliano15's Avatar
u should check out the lunati link bar lifters. i think they are made by the same company as morel which someone else mentioned. u can get rid of those plastic trays and they are made to handle more radical cams. also, less bleed down than the stockers or ls7s. i used to get a light valve chatter with the ls7s but with the lunati ones its almost silent.
Old May 16, 2018 | 10:39 PM
BlkOps's Avatar
Okay guys...... my car has 50k miles on it. I am spraying the car with 100 shot. I am doing an ms3 cam. It will be here tomorrow and is going in on Sunday. Do I need to do lifters?
Old May 16, 2018 | 11:39 PM
  #32
Not really.
Old May 17, 2018 | 09:46 PM
  #33
Floorman279's Avatar
i went with the 1 step better than stock morel 5315s. not the best, not the worst. good budget option that will handle lobes more aggressive than stock. one of the more time consuming things to replace in our motors, still surprising to me that many people in 2018 still choose to go with $100 ls7 lifters. back in 2010 i would get it, but in todays time, why not spend an extra 1-200 more for a part that is more than capable of taking half your motor with it when it goes. expecially after you possibly just put new heads on that you spent 2000 on......the morel 5315s aren't the best, but from research they are fairly forgiving in the amount of preload they accept and it was my first time measuring rods so wanted something that could compensate if i was off a little.
