Are Lifters recommended when installing a ms3 cam
Old May 22, 2013 | 08:37 PM
Silverbullet99's Avatar
Default Are Lifters recommended when installing a ms3 cam
So after throwing number out there with the possibility of getting a set of 243 or 799 heads which i would replace All gaskets and all parts while im in there incuding LIFTERS, if i cant find a set of heads are the lifters prone to getting worn down due to the aggressive cam ? And is it common or has anyone had lifter problems after using a big aggressive cam and stock lifters? Also will a set of ls7 lifters be ok for a replacement?
Old May 22, 2013 | 08:40 PM
groundZ-28ERO's Avatar
yes, use ls7 lifters. i learned this all to well after i had a stock lifter flatten out on wot. destroyed the cam.
Old May 22, 2013 | 08:52 PM
garygnu's Avatar
if your current lifters have some mileage on them ,consider ls7 lifters .also consider trunnion bearing upgrades with such a radical cam.
Old May 22, 2013 | 09:59 PM
badazz81z28's Avatar
"LS7" lifters are stock lifters. Don't expect wonders over the older lifters. Low spring pressures probably destroyed your cam by bouncing the lifter off of it. Anyways, its always a good idea to replace old parts while you are in there.
Old May 22, 2013 | 10:49 PM
Black 99 Bird's Avatar
How many miles on the stockers? If you are doing heads, yes change the lifters. If you are doing cam only with plans to do heads in the future I would wait.
Old May 24, 2013 | 12:48 AM
blackfbird98's Avatar
^this, i am literally in the middle of my cam and heads swap now and my car has 90,000 im so glad i decided to do my lifters and heads when i did my cam swap. if you decide to swap the lifters make sure you get new trays they get very worn out over time. i also did the trunion upgrade for my rockers its great insurance since i went with the texas speed v3 cam.
Old Jan 8, 2014 | 10:33 PM
SPAZ-3's Avatar
so all this being said a ms3 cam swap on my stock heads car 118k mi im going to want to do lifters and springs as well?
Old Jan 8, 2014 | 10:36 PM
jsteele90's Avatar
well you definitely need to do springs at a minimum as the stock springs are not stiff enough.
Old Jan 9, 2014 | 07:10 AM
2000PewterT/A's Avatar
I highly recommend doing lifters when doing a cam that large with a car with higher mileage. And you NEED to do springs, there is no way around that.
Old Jan 9, 2014 | 07:39 AM
HCI2000SS's Avatar
I have a cam almost identical to the M3, and use the LS7 lifters as well
Old Jan 11, 2014 | 12:13 AM
DREAMZ28's Avatar
From what I've read (from the more educational members on the board) the LS7 lifters are basically a stock replacement. Bad? No. But if you want an upgrade you should look at the BTR SLR lifters, or if you're trying to spend more change look at the morel lifters.
Old Jan 11, 2014 | 12:26 AM
Burken01's Avatar
Not everyone needs slow leak rate lifters, the cam, lobes, spring pressure all dictate which lifter to run in most cases..
That's why there are so many options because they all work better in certain situations.
Old Jan 11, 2014 | 12:39 AM
z28SSilvest's Avatar
Always good to get **** out of the way while things are apart. +1 for lifters
Old Jan 11, 2014 | 03:07 AM
peacesells63's Avatar
Not worth risking it in my opinion. If you have an issue, you will be pulling heads to replace lifters. Might as well do heads and lifters at the same time as the cam swap. I'm not planning on swapping out the cam on my ls6 just yet, but I am putting new ls7 lifters in while the heads are off.
Old Jan 11, 2014 | 05:17 PM
X2, no lifter will cover all applications, every lifter has a cam that it would work the best with, call sponsors and see what they recommend for the cam and then buy accordingly.
Old Jan 11, 2014 | 10:45 PM
JakeFusion's Avatar
Super Hulk Smash
The LS7 lifters bleed down at idle under pretty much all conditions.
I'd recommend the BTR SLR lifters as well. They are a billet body with a check valve vs a cast lifter body with a check ball like stock. Much better built.
If you have the cash to step up to a Morel or Johnson, I'd do that. The LS7 is decent if you have lightweight valves, low spring pressure, and grandma lobes. Otherwise, step up to something designed to withstand the environment of a performance engine.
Old Jan 11, 2014 | 11:26 PM
Darkstar632's Avatar
I have a ms3, when we swapped the cams I rebuilt the top end with ls7 lifters,ls2 lifter trays, prc 650 springs,titanium retainers/seats/ seals, Texas speed chromoly pushrods... That's the same setup your going to want to do, if you have the money go head and do the trunion upgrade too, I'll be doing that this winter with my head swap
Old Jan 12, 2014 | 12:06 AM
Burken01's Avatar
The key is to have the valve train setup with no lofting..
If it starts to loft and you have SLR lifters in the engine it will take the lifters longer to bleed down and seat the valves..
You would end up causing more damage with SLR lifter's vs ls7 lifter's if lofting is present..
Old Jan 12, 2014 | 12:23 AM
JakeFusion's Avatar
Super Hulk Smash
That's technically right. They take longer to bleed down... which means they would stay pumped up at higher RPM with loft. To get around this, you run less preload. Like .025" or so.
And loft happens because your pushrods flex and your cam lobe is violent enough that the cam lobe and lifter separate, usually on the closing ramp. You're going to damage the lifter and lobe in either combination.
The way around it is to run the proper valvetrain setup. For folks with the money, I say run a short-travel lifter. Then you essentially run a solid lifter at higher RPM, so you don't lose valve lift or have pump up issues.
Old Jan 12, 2014 | 12:48 AM
Burken01's Avatar
Yes I'm keeping the short travels in mind, if I notice any problems with mine I'm going to yank them out ASAP
