gugs running EnglandGreen cams chine in please
Of those of you that are running these cams did you have them install it or did you do all the work yourself?
I received my cam from them and didn't receive a cam card, all the specs are scratched out and not even a grind number. Are they this strict with there cam specs?
FOR sure find out the grind. you don't want to be in the situation I am, I bought my car used and have no idea what grind the aftermarket cam is. Sounds like you got a cam off the mystery shelf.
Location: Somewhere Between Mild Insanity and Complete Psychosis
Make a post on Corvette Forum in C5 or C6 tech asking if anyone has the specs. Someone probably will.
Same deal with LG. They don't publish specs but you can find them if you ask around.
Quite a few guys running the Whiplash cam IIRC. I can't remember all the rest of his cams by name. EG is a good friend and I believe I was probably his first commercial customer --- he started the supercharger install work on my vehicle back in '07 at his private residence and finished it once he moved into a commercial space shortly thereafter --- BUT I'm not really into the hype with cams with cool sounding names, aggressive lobes, and specs shrouded in secrecy. Ask in the right places and ye shall probably receive. Most of his customers are on CorvetteForum.
ah alright thanks gentlemen, the only thing the cam has grinded is mayhem II which i ordered but no specs, the only info i have is the rough 23x/24x 63x/64x/ 113lsa
